Author Topic: Omega FL Instrument Panel Bulbs..  (Read 5578 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« on: 01 April 2014, 23:40:51 »
..My local VX dealers haven't a clue what type the Omega have and want me to remove the fused bulbs and bring them in so they can order, Which is not happening, Why this is so complicated for them is beyond me...  >:(
Can someone provide me with the name of the bulbs and all the different types.. or eBay links etc.
I need one main beam, EML, and right side background illumination bulb..
This would be much appreciated, VX are driving me crazy..
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Omega FL Instrument Panel Bulbs..
« Reply #2 on: 02 April 2014, 02:18:11 »
« Last Edit: 02 April 2014, 07:12:15 by RobG »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #4 on: 02 April 2014, 07:39:06 »
Main illumination bulbs (4)
http://www.autobulbsdirect.co.uk/505-3W/
Warning bulbs
http://www.autobulbsdirect.co.uk/R509TOR-BX8.5D-Panel-Bulb-12V-1W-Orange-Base.html
Main beam
http://www.autobulbsdirect.co.uk/Headlight-bulbs-standard/
Thanks Rob  :y
Should have made myself clearer sorry  :-[ .. Main beam as in that's one of the instrument panel bulbs that's not working/fused, That'll be the warning bulbs then  :y
« Reply #5 on: 02 April 2014, 08:20:56 »
Warning bulbs
Main beam
Thanks Rob  :y
« Reply #6 on: 02 April 2014, 08:36:50 »
It's only four screws to remove the cluster...
Drive to the dealer, dump it in the middle of the forecourt and pop the cluster out. Refuse to move the car until the cluster is refitted. Might learn the parts bloke to be less retarded ::)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #7 on: 02 April 2014, 20:04:45 »
Warning bulbs
Main beam
Thanks Rob  :y
Thanks again Rob, Ordered  :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #8 on: 04 April 2014, 20:08:35 »
Well I replaced the bulbs today and also found a lose bulb behind the instrument panel which would have been causing that ratteling type sound I've been dealing with for many many months  ;D
There is a snag...The new 3W ( http://www.autobulbsdirect.co.uk/505-3W/ ) background illumination bulbs unfortunately seem too weak, very dim in comparison to what they where like.. Maybe i need 2W  :-\
« Reply #9 on: 04 April 2014, 20:20:52 »
3w bulbs will always be 50% brighter than 2w ones ::)
Would start by adjusting the dimmer switch :-X
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #10 on: 04 April 2014, 20:22:27 »
 Goes without saying ::)  .. If i dim it all the way down they are almost off no light at all...
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #11 on: 04 April 2014, 20:34:31 »
Doesn't really show well in the video..
http://youtu.be/eEqlPaO7jzE
« Reply #12 on: 04 April 2014, 20:41:53 »
Ah, you've broken it then...
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #13 on: 04 April 2014, 20:48:22 »
Right then, I tested one of these 3W bulbs I have left over and it's dim with a car battery charger at 12V... Looks like i'll have to pop to VX or Halfords and take one of the original fused bulbs with me...
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #14 on: 04 April 2014, 21:31:48 »
Think i know why these are so dim now, Looking closely it says 24V 3W http://www.autobulbsdirect.co.uk/505-3W/ ..Shouldn't it be 12V 3W  :-\
