Author Topic: Something different  (Read 980 times)
Something different
« on: 12 June 2008, 09:28:09 »
For any aviation/engines interested folks .....
http://www.flightglobal.com/blogs/unusual-attitude/2008/06/europrop-engine.html
BTW .. the clearance between the prop-tip and the fuselage is .....  6 inches !!!!  They've had to put bracing struts in to stop it twisting itself off, and the "chocks" were specially designed !!
It is estimated that when the flight trials start, the new engine at "flight idle" power will produce the same thrust as an existing "old" one (Alison T56-15 !) at max power !!
Awesome  !!
http://www.airbusmilitary.com/press.html
« Last Edit: 12 June 2008, 09:39:19 by entwood »
Debs.
Re: Something different
« Reply #1 on: 12 June 2008, 09:33:24 »
 :y Brilliant.......what a beast! :y
« Reply #2 on: 12 June 2008, 10:49:44 »
So what turbine is driving the prop......not the new eurojet?
« Reply #3 on: 12 June 2008, 11:24:29 »
All here .. :)
http://www.rolls-royce.com/defence_aerospace/products/transport/tp400/default.jsp
Martin_1962
« Reply #4 on: 12 June 2008, 12:39:27 »
Another co production from the main European gas turbine companies, RR of course included.
SNECMA as well - they helped a little with the Bristol Siddley Olympus Concorde version
Martin_1962
« Reply #5 on: 12 June 2008, 12:41:15 »
Hm 28%, and the general architecture
