Author Topic: Air con overhaul  (Read 1955 times)
joshwyatt
  • Online Online
  • Oxford
Air con overhaul
« on: 02 April 2014, 21:37:36 »
Both of my Omega's have U/S air con, and today I've finally decided to sort that!
It's a bit like asking how long is a piece of string, but what are the weak points?
For example, washers on the compressor, worthwhile just replacing condensor and drier/receiver as they're not overly expensive?
I'll take a trip to kwikfit, but suspect they'll gas it and tell me it's fine  ::)
Re: Air con overhaul
« Reply #1 on: 02 April 2014, 21:41:30 »
If the condensers appear intact then swap out the valves and get them regassed :y
If condensers are shot, ie bits hanging off the bottom edge, change them too...
Your black one has had a new valve fitted to the rear fill point (by the oil filler), and I have a spare valve for the front one. So just need one of each for the white one :y
Just to add, the system needs filling in order to test it, as the compressor won't run with no gas, so I woukd swap the valves, then get kwikfit or whoever to regas them and go from there :y
« Last Edit: 02 April 2014, 21:43:17 by Taxi Al »
« Reply #2 on: 02 April 2014, 21:42:20 »
condensors are a weak point due to being right at the front where they get all the sh1te & salt thrown up from the road surface. Then compressors I would say. I also had a leak on one of the fill points (the one Grrr has just been posting about, right at the front of the engine bay) and one of the pressure switches.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #3 on: 02 April 2014, 21:44:53 »
Easiest things to replace first are the hp and lp valves,these are prone to leak and cost pence, a new compressor will cost about £150 a condenser about £90, if the evaporator is gone then that's a dash out job. Also check the fuses. :)
there's also a valve hidden behind the glove box, and the pressure sensing valve at the front they cost £55,(its got a switch in)
« Last Edit: 02 April 2014, 21:47:44 by biggriffin »
Hoof'land storeman.
joshwyatt
  • Online Online
  • Oxford
« Reply #4 on: 02 April 2014, 21:58:57 »
Thank you gents, excellent info as always  :y
« Reply #5 on: 03 April 2014, 19:32:04 »
The weak points on Omegas are condenser, valves, compressor and the pipe that runs up the chassis leg to baukhead.
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #6 on: 05 April 2014, 12:53:41 »
Josh there is a place in Bicester that I have used and they are pretty good Bicester Auto Electrics
www.bicesterautoelectrics.co.uk
Unit 37, Wedgwood Rd, Bicester
01869 357740
tidla
  • solihull
« Reply #7 on: 05 April 2014, 20:12:58 »
Slight hijack, is the compressor diy repairable? Got dye showing in the centre of mine. works for about 9 months before it stops.
« Reply #8 on: 06 April 2014, 18:32:00 »
Believe Shackeng did his last summer :y
