Author Topic: leak at rear of engine  (Read 5433 times)
brian36
  • Milton Keynes
  • 2.6 mv6
Re: leak at rear of engine
« Reply #15 on: 04 April 2014, 19:12:40 »
New dealer info
http://www.thurlownunn.co.uk/locations/milton-keynes/
thanks yip even know where it is pass it daily to and from work will get car looked at and get one asap if this the case thanks
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #16 on: 04 April 2014, 19:14:24 »
As Marks DTM suggests, if its leaking when climate set to HI (for eg), try it with climate set to LO, or vice versa.  This usually points to HBV, about £30+VAT from dealer, trade, although avoid the scumbags at Crownhill (V4, between H5 and H4).  I'm told a new dealer has recently opened at Kingston, near the BP, on the way to the M1 Jnc 13. No idea if its Crownhill moving, or a separate dealership.
I'm in Brackley, on the Bucks/Northants/Oxon border if you need a 2nd opinion, or help.
will try in morning hard day need to sit down thanks :y
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #17 on: 06 April 2014, 15:20:49 »
so the update, after initial leak which lost me about 2 inches in expansion tank i filled up and since then nothing. have had aircon on at hi and ran for about 15 mins then put on low for same i then drove back and forward work 2 days still ok weird or what?
will keep a eye on it but thanks to all :y
« Reply #18 on: 06 April 2014, 15:24:43 »
You'll most likely find it all escapes at one temperature setting. Try a different temp each day until it leaks...
The only consistency with HBV failure is that the temp is always different ::)
  • Auckland
    • Mazda MPV
« Reply #19 on: 06 April 2014, 15:27:42 »
Symptoms are typical of HBV.
I would buy a new HBV anyway so that it is in the car ready to fit when the old one fails completely.
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #20 on: 06 April 2014, 18:42:41 »
ok i reckon will buy one just in case and thanks again :y
brian36
  • Milton Keynes
  • 2.6 mv6
« Reply #21 on: 18 April 2014, 19:17:00 »
theboy
hi would you be able to have a look if can get over to you this weekend if you are free? would appreciate it thanks
« Reply #22 on: 27 April 2014, 09:10:59 »
Had a gander at this today, although buggered if I could get it to leak, using the modified cap and pressurising to about 10psi method  :-\
Valley is bone dry, no hint of leak from stat, cooler plate, bridge, HG (to outside of block). Good job there, Mr DTM :y
Bits of radiator that are visible all looked good, as did rad hoses. Curly hose from bridge to HBV looks good.
Tell tale signs ("rusty" look) of a leak around HBV, which would fit in with brian36's diagnosis of where he's seem coolant under car, and with his observations with the climate settings within the car.
Disappointing I couldn't 100% prove the leak, but given what I've seen, the HBV is what I would do :)
