Author Topic: obd 2 scanner  (Read 4381 times)
badmuver
obd 2 scanner
« on: 06 April 2014, 14:12:30 »
Hi all, i'm looking at getting a scanner for my car, I've found this one i was just wondering if it is and good.
<Link removed by Admin>
cheers   :)
« Last Edit: 06 April 2014, 16:09:19 by TheBoy »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: obd 2 scanner
« Reply #1 on: 06 April 2014, 14:17:57 »
cheers   :)
Says this ? - XP SYSTEM ONLY
« Last Edit: 06 April 2014, 16:09:27 by TheBoy »
badmuver
Re: obd 2 scanner
« Reply #2 on: 06 April 2014, 14:19:35 »
yep i've got a old netbook on xp  :)
Re: obd 2 scanner
« Reply #3 on: 06 April 2014, 14:28:44 »
Chinese shite. Click on "contact details" bottom left of page and you`ll see this
黎杰仪
白云区时代玫瑰园三期H2栋403房
510440 广州市, 广东省
中國
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Re: obd 2 scanner
« Reply #4 on: 06 April 2014, 14:53:42 »
I brought a maxiscan 309 for about £13 quid off eBay. Works rather well tbh
« Last Edit: 06 April 2014, 14:56:08 by plym ian »
Re: obd 2 scanner
« Reply #5 on: 06 April 2014, 15:13:26 »
That is NOT a "Tech2" .. it is an ELM327 .. and a clone one as well .. touch not with a bargepole IMHO..
A proper "Tech2" will set you back a lot more than that ...
http://www.diagtool-uk.co.uk/GM_TECH_2_VETRONIX_DIAGNOSTIC_TOOL_INC_32MB_VAUXHALL_CARD/p2499210_11579572.aspx
badmuver
Re: obd 2 scanner
« Reply #6 on: 06 April 2014, 15:17:35 »
Cheers RobG for pointing that out.  ;D
plym ian,  maxiscan 309 what dose this one cover.
Re: obd 2 scanner
« Reply #7 on: 06 April 2014, 15:23:32 »
Read about the Maxscans here ... all made by Autel .. again .. avoid ebay as most of those are illegal copies that generally don't work..
http://www.auteltech.com/
I have the GS500 (no longer made) that is an early Autel maxscan .. excellent bit of kit, but only does engine and a little bit of transmission
badmuver
Re: obd 2 scanner
« Reply #8 on: 06 April 2014, 15:23:57 »
cheers lucky i didn't get one.  :)
badmuver
Re: obd 2 scanner
« Reply #9 on: 06 April 2014, 15:34:51 »
So would the maxiscan 309 cover the light that comes up with the car and the spanner in the middle, as it bugs me when i am driving and it comes on.  :(
plym ian
  • Plymouth, Devon
Re: obd 2 scanner
« Reply #10 on: 06 April 2014, 15:51:55 »
All codes cause by eml on. Not sure about spanner light :(
Even told me had misfire on pot 4 as well :y
Re: obd 2 scanner
« Reply #11 on: 06 April 2014, 16:10:23 »
Links removed as looks suspiciously like an illegal copy of a commercial product.
badmuver
Re: obd 2 scanner
« Reply #12 on: 06 April 2014, 17:49:36 »
cheers everyone  :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: obd 2 scanner
« Reply #13 on: 06 April 2014, 17:59:06 »
Good luck getting an Autel to read Omega codes. Will read live data though.
That's not to say the Autel isn't a good scan tool. It's read and erased codes from every car I've used it on except the Omega. Handy for me as I work on lots of cars but as said don't expect it to read Omega codes.
Wonder why it won't?  :-\
RIP Paul Lovejoy
Re: obd 2 scanner
« Reply #14 on: 06 April 2014, 18:53:17 »
Autel GS500 reads codes, erases codes, reads live data on mine, and every other FL omega I've tried with ease .. although it doesn't work on PFL, and has limited success on MFL .. its all to do with the OBDII standard .. if the car is not OBDII then the maxscan can't read it .. :)
