Author Topic: How much lower.  (Read 1850 times)
tooleater
  • Rickmansworth,  Herts
    • Go faster Black MV6 Man
How much lower.
« on: 07 April 2014, 11:36:38 »
As I'm looking to get Daz replace the springs and shocks on my Facelift 2000 3ltr Mv6 with Vx parts which are going to be serious ££ s :o. Can someone tell me how much different the motor going to look if I install aftermarket set. Ie how much lower +stiffer in comparison to Vx running on standard 17 Mv6 rims :y
chrisgixer
Re: How much lower.
« Reply #1 on: 07 April 2014, 14:53:06 »
Standard omega is 675 mm to the wheel arch
Face lift mv6 is 15mm lower.
After market are mostly 30mm lower than standard. So a further 15mm lower than face lift mv6 (lowered sports chassis) as you have. Assuming your springs are lsc. As you know they are expensive so the previous owner may have gone for cheaper ones.
tooleater
Re: How much lower.
« Reply #2 on: 07 April 2014, 15:05:36 »
It's dropped more than that on Nsr, that's the side diff leaking could the oil have knackered a bush, or is the broken pigtail on Nsf contributing to the slouch. Hence full set..
chrisgixer
Re: How much lower.
« Reply #3 on: 07 April 2014, 15:10:04 »
It would do, as the spring is broken. The bush might be knackered but I'd be surprised if the dif oil caused it. (Might help it on the way though I suppose)
chrisgixer
Re: How much lower.
« Reply #4 on: 07 April 2014, 15:11:17 »
Btw, I'd advise against lowering the rear more than 20mm, as the settings are difficult to achieve below that point. Front is ok. Ime.
tooleater
Re: How much lower.
« Reply #5 on: 07 April 2014, 16:24:19 »
Thanks Chris, your last post sealed it for me about not going lower than 20mm on rear. The drop on rear May well be a duff spring, so Vx springs it is, will get a T.C and explore all avenues to reduce price. 1 more ? Are front struts/shocks different as well :y
Re: How much lower.
« Reply #6 on: 07 April 2014, 17:58:08 »
As others have said, 30mm on the rear is too much if you need to negotiate speed bumps etc. Definitely too low if you have the chavtastic Irmscher saloon rear bumper  :-[
It also give quite a lot of camber on the rear as well, though my (normal height) MV6 has more anyway due to other issues, with no detrimental effects.
chrisgixer
Re: How much lower.
« Reply #7 on: 07 April 2014, 18:12:58 »
Yes. But not any more or less expensive for being lsc. So you do need lsc shocks for the face lift mv6. They need to be the right ones.
ted_one
Re: How much lower.
« Reply #8 on: 07 April 2014, 18:30:28 »
My 3.0 ltr ex plod MV6 is being done as we speak,but with Eibach springs and Bilstein B4's,so hopefully it will work out O.K. :-\
symes
  • oxford
    • R reg 940 volvo
Re: How much lower.
« Reply #9 on: 07 April 2014, 18:53:41 »
I had a lowered miggy---totally useless pig of a thing to use on a daily basis--Kept grounding out on speed humps and some mot places refused to mot it--something about getting it on a lift----anyway-got rid of it in the end and got a decent car---obviously it was a mig--Happy days--oh it was lowered 30mm before you ask-in fact took it to some Oxford oof meets there is pics of it here somewere -
chrisgixer
Re: How much lower.
« Reply #10 on: 07 April 2014, 18:58:48 »
Mines 30 lowered at the front with Irmscher springs.
15 lower at the back with mv6 lsc springs.
B4 all round.
No issues day to day. Just need to take speed humps at a sensible speed or the front air dam rubs the floor a bit otherwise.
Re: How much lower.
« Reply #11 on: 07 April 2014, 19:04:49 »
B4 all round.
Small bridges are the problem around here, you need to remember to slow right off. That said, the Irmscher one does hang a lot lower than standard.
tooleater
Re: How much lower.
« Reply #12 on: 07 April 2014, 19:46:06 »
Irmscher who said anything about Irmscher ;D I am trying to get this motor back up to an acceptable factory spec but not that spec guys :y
