Pages: [1] 2 3  All   Go Down
Author Topic: spluttering?  (Read 5206 times)
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
spluttering?
« on: 11 April 2014, 04:53:17 »
As title says.... Ticks over just fine but under acceleration taking it to 2000rpm ish it starts to splutter... The engine management light comes on at that point then goes off when back down to idle speed... Ant ideas?? :-[
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: spluttering?
« Reply #1 on: 11 April 2014, 05:56:26 »
Any codes?
vauxsull
    • 3.0 Elite
Re: spluttering?
« Reply #2 on: 11 April 2014, 06:02:44 »
Only started this morning so just parked up in work... Don't know how to check for codes anyway :D.  Thinking about it now its not so much a splutter but revs up and down rapidly (as if you where pressing accelerator on and off)
vauxsull
    • 3.0 Elite
Re: spluttering?
« Reply #4 on: 11 April 2014, 08:51:52 »
I shall give this a try during my break time thanks... Car doesn't seem to mis fire just race up and down during driving not idling so would the pedal trick still pick something up?
Re: spluttering?
« Reply #5 on: 11 April 2014, 10:52:10 »
Worth a check of the codes anyway :y
Possibly a simple air leak though... easily checked/located with a can of carb cleaner :y
vauxsull
    • 3.0 Elite
Re: spluttering?
« Reply #6 on: 11 April 2014, 10:54:47 »
How can i check with cannot carb cleaner to check for air leak??
vauxsull
    • 3.0 Elite
Re: spluttering?
« Reply #7 on: 11 April 2014, 10:56:02 »
Can of... Not cannot... Stupid phone
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: spluttering?
« Reply #8 on: 11 April 2014, 10:59:48 »
Check icv valve,were it goes into the plenum, also remove icv and give it a good clean with carb cleaner or cellulose thinners. Think there's a guide.
Hoof'land storeman.
Re: spluttering?
« Reply #9 on: 11 April 2014, 11:01:41 »
Engine running, spay short bursts around any vacuum/breather connections and around the plenum. When the engine note changes, you have found the air leak :y
Don't smother it in the stuff though, as you might lose your eyebrows ::)
Check for codes first though just in case there's any listed...
Biggriffins suggestion is a sound one too as that will also give similar symptoms :y
vauxsull
    • 3.0 Elite
Re: spluttering?
« Reply #10 on: 11 April 2014, 11:08:12 »
So it could be something as simple as that then? And an air leak would cause the eml to come on too? It is fine on tick over !!
Re: spluttering?
« Reply #11 on: 11 April 2014, 11:10:53 »
It could do :-\ basically the engine is receiving more air than it's providing fuel for, so it burns unevenly and the revs hunt as the ECU tries to compensate for this extra air that it cannot measure :y
If it idles ok, then that does rule out the Idle Control Valve :y
vauxsull
    • 3.0 Elite
Re: spluttering?
« Reply #12 on: 11 April 2014, 11:12:25 »
I shall do the paper clip test around midday and see if there's a breather pipe come adrift ..
vauxsull
    • 3.0 Elite
Re: spluttering?
« Reply #13 on: 11 April 2014, 11:52:45 »
Unless I'm doing this simple task wrong its flashing 2. 1. 2 1 ? :-\
Re: spluttering?
« Reply #14 on: 11 April 2014, 12:59:40 »
21 is the fault code :y decipher list is in the maintenance guide section :y
Cross posting from a mobile is a pita, but go to the index and it's easy enough to find...
Pages: [1] 2 3  All   Go Up
