Pages: 1 [2] 3  All   Go Down
Author Topic: changing the battery location..  (Read 6637 times)
Re: changing the battery location..
« Reply #15 on: 11 April 2014, 23:55:16 »
I was waiting for you to comment ;)
Moi!  ::)
« Reply #16 on: 12 April 2014, 09:09:19 »
I guess making room for a turbo?
Biggest issue I can see are the secure mounting (which shouldn't be too hard), and the cabling (quite awkward to run that sort of cable, ask any chav who has fitted a 10,000gigawatt amp in the boot ;D).
« Reply #17 on: 12 April 2014, 09:18:00 »
Turbo  :)
Anyone superchaged an Omega yet  :-\
« Reply #18 on: 12 April 2014, 09:43:02 »
The battery in my Jag is in the boot (as standard) - no issues day to day, but downsides . . . would be a pain in the arse to change as fitted under boot floor next to spare wheel, so empty boot, lift floor, and battery itself is huge (354x175x190mm) and weighs 25Kg, and is awkward to reach!!! :-\
opps.. really surprising.. :o     thanks Dbug :y
« Reply #19 on: 12 April 2014, 09:47:06 »
Having the battery in the boot is very handy when your battery dies in the car wash queue.  ::)
Jump leads straight to the car behind and I was in the wash, left the engine running during the wash and I was away!  :y
The bird in the car behind was a bit arsey about it though.  ::) ;D
2 weeks ago night time , one friend with a 7 years old automatic honda called me.. battery dead..  we cant move the car and his parking position was a nightmare because cables were not that long..  to cut the story short I had to drive the clit into a high kerb and climb :(
« Reply #20 on: 12 April 2014, 09:50:21 »
The older BMW 3 series and M series, to name a few had the Batteries in the Boot, from memory some were the same size / spec as the Omega's (065) but with a vent tube from the top of the battery, Some 065 Battery's come with the vent hole plugged, so a tube can be inserted to go the the boot floor, see pics below.  ;)
Also worth considering having a additional Positive Jump Point, wired directly to the starter motor and good Engine Earth point in the Engine Bay, for two reasons, 1, so you dont have to empty the Boot to jump Start your Car, and 2, a shorter lead resistance to the Starter Motor when your rear Battery is flat. Again you can get the Engine Bay parts from a BM, Jeep, Porshe etc, see last Pic  :y
thanks for the explanative answer Zirk :y  all noted..
« Reply #21 on: 12 April 2014, 09:57:35 »
Biggest issue I can see are the secure mounting (which shouldn't be too hard), and the cabling (quite awkward to run that sort of cable, ask any chav who has fitted a 10,000gigawatt amp in the boot ;D ).
 ;D  yep.. and not only that.. the only part you cant estimate is its not for omega.. I decided to keep it as it is.. as the car is very healthy and it took me many years and a serious cost to bring the car to that point.. may be only I will bore it to 3.0 .. and its my long range transport so I dont want to face any problem while on a mountain passage.. and one more point even with that engine (currently 188 hp) , it can travel many times the legal road speed ..
 but clit definitely needs space under the hood.. not only battery also all air inlet boxes removed .. and in re-building stage now.. :-\
ps: at first I decided to turbo the miggy.. apart from the cost, its not my daily drive because I have a big big big parking problem in job >:(
although I prepared all necesssary info and read zillions of pages , I finally decided for clit
« Last Edit: 12 April 2014, 10:04:01 by cem »
« Reply #22 on: 12 April 2014, 09:58:34 »
Turbo  :)
superchargers are more expensive and most tuners dont know how to tune it.. :(  and try to avoid it for some stupid reason
« Last Edit: 12 April 2014, 10:05:38 by cem »
symes
  • oxford
    • R reg 940 volvo
« Reply #23 on: 12 April 2014, 10:30:34 »
easyiest way to mount battery in boot is get a battery box-thats what I got--battery is completely encased in box---or make your own box cem--that should be quite easy to do  :y :y
« Reply #24 on: 12 April 2014, 13:25:43 »
Not to hard to do.
You will need a mount plate and strap (plenty available from the likes of kit car suppliers and many modern cars fully enclose the batteries)
Cable will need to be substantial, not worked out the volt drop but I would expect at least 25mm2 required for the pos and a good short cable to the chassis for the neg.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #25 on: 12 April 2014, 14:21:47 »
Yep, as said above, Bm's have a 'positive terminal post' under the bonnet. It is now a 'post' rather than the connection box and is available as a bracket. The battery compartment is in the boot and the leads are fitted with detonators (or whatever they are called) to disconnect the battery terminals in the event of an accident. Otherwise there is no quick way of isolating the battery terminals to stop it shorting in the event of an accident.  :y
« Reply #26 on: 12 April 2014, 16:15:55 »
thanks Symes.. probably a custom box/chasis will be built :y
« Reply #27 on: 12 April 2014, 16:18:24 »
Not to hard to do.
as starters we will use 6 mm thick cable.. thanks Mr DTM :y
« Reply #28 on: 12 April 2014, 16:20:00 »
thanks .. noted :y
« Reply #29 on: 12 April 2014, 17:06:34 »
Being a clit...
Battery in boot on rhs, nothing under the boot floor except spare, try and bolt it down to the tail of the chassis rail (such as it is) but be sure to avoid/allow for the spare wheel contact points. I would locate it against the wheel tub, as near to the back rest as practical to keep it away from the rear corner just in case.
Run the cable down the centre of the car, shielding it as it passes the handbrake/gearlever and route it to the batteries original location through a convenient hole in the bulkhead. Mount the remote terminal here as well :y
Pages: 1 [2] 3  All   Go Up
Page created in 0.027 seconds with 16 queries.
