Author Topic: Rear boot spoiler Removal  (Read 4116 times)
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
« on: 12 April 2014, 15:55:33 »
How does it come off?
 There is a small screw either end of the spoiler (accessible via the boot lid).  These have been removed but spoiler won't budge. Is it held on with clips and tape (like the black door strips) or is it just bonded on?   :-\
The faster you go the bigger the grin.  Trade card user.
Re: Rear boot spoiler Removal
« Reply #1 on: 12 April 2014, 16:18:29 »
F/L, MFL, saloon or estate :-\
RolandL
  • Doncaster
« Reply #2 on: 12 April 2014, 16:25:25 »
Sorry Rob, should have been more specific.   ;D
It is a Mini Facelift '99 saloon. Boot spoiler is Irmscher and lays flat on the boot lid.
« Reply #3 on: 12 April 2014, 16:33:19 »
Stiff bladed scraper and lump hammer. Start from one end with scraper under top part of spoiler, tap with hammer until you`ve freed up about 150mm, place scraper under bottom part of spoiler and do the same. Repeat process until about midway across bootlid then do the same from other end.
Takes me about 10 minutes.
RolandL
  • Doncaster
« Reply #4 on: 12 April 2014, 16:40:14 »
So it's bonded then.  Thanks :y
Would you also be able to answer this question as well.
I have taken off the plastic sill covers, just above the cover and just below the door opening there is a rubber weather strip (goes full length of the side)  I need to remove it so I can tackle a little rust.  It appears to sit on some thing Metal?  Can't feel any clips.  Does it just pull off/push on?
« Reply #5 on: 12 April 2014, 16:42:49 »
IIRC it`s a tight push-fit
RolandL
  • Doncaster
« Reply #6 on: 12 April 2014, 16:46:48 »
Thanks Rob, you are a star  :y :y :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #7 on: 12 April 2014, 16:54:53 »
As Rob says, I now use a blunt Axe and a Club Hammer, start about 1mm away from the top of spoiler working each end towards the middle. then normally pulls off from the bottom.
Use to take me about half an hour, but since using Adam the Axe and Charlie the Club, got it down to 3 mins now  :P
And if I find the Batwerds that took the car, I shall do it to there Heads in even less time.  :(
« Reply #8 on: 12 April 2014, 17:52:59 »
It's a push fit onto what looks like a flat headed nail welded to the body.  ;)
RolandL
  • Doncaster
« Reply #9 on: 12 April 2014, 20:06:18 »
AndyB,
 so when I squash the weather strip, the bit I thought was "Metal" is in fact part of the weather strip, and it's this that pushes into the "flat headed nail"?
flyer 0712
« Reply #10 on: 12 April 2014, 21:41:29 »
Did mine by using a gas blow lamp on the inside of the boot lid...(not required ) and used a scraper on the outside between boot and spoiler....easy peasey.....then put onto my other car with bonding glue.. :y
