Author Topic: Lawn Mower Engine - Air intake gasket.  (Read 3220 times)
Re: Lawn Mower Engine - Air intake gasket.
« Reply #15 on: 14 April 2014, 23:40:39 »
Electric mowers are a bit poofy, but by the time you guys have got yours going I've plugged in, whipped around and have my feet up admiring my handiwork!  :y
.. unless you maintain your mower, in which case it starts quicker than it takes to get the extension lead out. ;)
I've got an Omega, I don't want a mower that needs constant fettling as well!  :P  ;D
Nice post..............  :D :D :y
« Reply #16 on: 15 April 2014, 03:16:57 »
My mower doesnt have an idle jet .....
You press the bulb several time to flood the carb.....then keep the lever pulled back on the push bar.....and pull the cord....it usually goes first time with loads of white smoke to start with on full throttle and stays on full throttle until you release the the lever which not only kills the engine but puts a brake on the blade  :y
It will still have an idle jet setup
« Reply #17 on: 15 April 2014, 08:52:53 »
I've got an old lawn mower thanks to FatherT  :y
It's engine is a Briggs & Stratton Quantum XM 35, was a pig to start this year. So took off the float, cleaned it all up, fairly clean anyway, blast of carb cleaner in all its bits, new air filter and put it back together. Problem was the gasket on the air-intake was in a right state, so took it off for now. Re-assembled, without gasket.
Pull cord 3 times to prime, pull again and bang, straight into life.
Runs well, apart from after a while, the revs get very lumpy, it gets so bad it stops every so often. I'm thinking as it heats up, it's letting air in at the intake, more than it should, lack of gasket giving it lumpy hot revs?
Thinking of this:
http://www.ebay.co.uk/itm/Briggs-Stratton-Carburettor-Gasket-Set-fits-Max-and-Quantum-Engines-/221242600987
But can I use a liquid sealer? Or is better off going for one of these kits?  :-\
Check how clean the petrol tank is and any filter in there, as they have a tendency to collect grass cutting over time which as you use the mower migrate to the fuel filter and block it, when the engine stops they are released from the filter and when you start it the cycle starts again.
Thanks, not seen a filter, when I removed the fuel line to the float, it was pouring out nicely, had to stand the feed pipe vertically with some paper towels in it.
As I'm not used to Carbs, I released the bolt holding the float and pondered for a few minutes why it was still draining fuel out of the tiny cap  ::)
Tempted to drain the tank actually, as for many years it was left over winter with fuel in it.
Is the filter at the bottom of the tank? I've not seen one  :-\
« Reply #18 on: 15 April 2014, 08:53:44 »
It's never had an oil change either, GM 10/40 Semi ok  ::)  ;D
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #19 on: 15 April 2014, 08:54:53 »
Tunnie - when I was your age I messed with petrol mowers. The older ones are a pain in the ass and if you value your time go out and get something that does the job - electric or petrol.
Parents give you stuff believing they are helping you out and you feel obliged to deal with the problem which is why they gave it away to you in the first place.
Time is money ...
« Reply #20 on: 15 April 2014, 10:52:45 »
Time is money ...
There is truth in that, but the lawn area I have is not vast.
FatherT did buy himself a new Mower as this one was becoming problematic, but like the Omega, a little TLC and it could run for a good time yet.
« Reply #21 on: 15 April 2014, 11:30:57 »
Time is money ...
If you enjoy tinkering with it, then it's not wasted time. If it saves you a couple of hundred quid on a new mower, so much the better.. IMHO, at any rate. :y
« Reply #22 on: 15 April 2014, 11:40:16 »
Time is money ...
It's done exactly that, even with it's current 'issues'. I did enjoy a little tinker with it, never done anything with Carbs or floats, so all new to me. Being basic as well, nice and easy. It's a welcome change in pace from work IT stuff  :)
Back to one of my questions above, is there a fuel filter on these things?
« Reply #23 on: 15 April 2014, 13:01:05 »
Probably a screen built into the bottom of the tank. Best thing to do is to remove the tank and give it a rinse out with some soapy water, rinse it well and leave it in the sun to dry before refilling.
Rods2
    • 1999 3.0 Elite Estate
« Reply #24 on: 15 April 2014, 19:46:29 »
Time is money ...
I agree, mine when it started to give trouble was easily solved with a service and £7 for parts. It now needs a bit of welding where tin worm is taking its toll on the blade cover, but an offcut from the blacksmiths down the road, and a bit of welding practice, should hopefully have it ready for the next 18 years. :y :y :y
