Author Topic: front suspension clonk  (Read 2606 times)
maverick
« on: 18 April 2014, 14:55:05 »
this may have been answered elsewhere but I have looked and couldn't find an answer ...
recently I've started getting a clonk over bumps on the drivers side front suspension. the steering's a bit wayward too. the usual suspect is a track rod end as when I jack up the car and try rocking it between 12 and 6 o clock positions there's nothing, but rocking between 3 and 9 gives the noise ...
I got a new track rod end and disconnected the old one from the hub ... the old one. which isn't that old. is still good with no play at all in it. its still good and stiff,  if fact I replaced all four track rod ends just last year .. when I tried rocking the wheel with the track rod disconnected I still seem to be getting the noise.
its difficult to pin the exact source of the noise on my own. is it possible it might be the top strut mount ?
Re: front suspension clonk
« Reply #1 on: 18 April 2014, 15:03:08 »
Droplinks possibly
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #2 on: 18 April 2014, 15:04:13 »
Usual suspects (but not always) would be Droplinks. More noticeable over speed humps.  :y
If steering is a bit wayward, could be wishbone bushes, but not necessarily linked to the clonking.  :-\
maverick
« Reply #3 on: 18 April 2014, 15:55:49 »
I'll check the drop links, only replaced them last year for the MOT but they were cheap ones ... both wishbones have been replaced within the last couple of years and I replace the front bushes with poly ones ... so I'm hoping its not them :)
« Reply #4 on: 18 April 2014, 17:35:14 »
Life expectancy of cheap wishbone bushes/ball joints/droplinks range from a week to two years :y
Less than a week and you're unlucky, over 18 months and you're doing well...
« Reply #5 on: 18 April 2014, 19:21:49 »
My vote is for droplinks - when failed give a rattling/knocking noise more obvious over a rough road ;)
« Reply #6 on: 18 April 2014, 19:44:40 »
maverick
« Reply #7 on: 03 May 2014, 14:59:19 »
ah well, replaced bottom arms and droplinks ..... and ........ the clonk is still there !!  b*llocks
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #8 on: 03 May 2014, 16:02:08 »
Droplinks definitely usual suspects (I've just replaced mine again).
It's not a broken spring? You'd have noticed that probably, and is there any play in the shock?
chrisgixer
« Reply #9 on: 03 May 2014, 17:46:17 »
Check steering idler for play.
Tighten steering box bolts to body if nothing else is obvious.
« Reply #10 on: 03 May 2014, 22:59:23 »
Might be worth checking the anti-roll bar bushes too, but they rarely fail on an Omega. :-\
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #11 on: 04 May 2014, 07:41:50 »
What about the track rods ball joints :-\
MV6Matt
  • London
    • No car since 2022....
« Reply #12 on: 04 May 2014, 08:32:03 »
....especially if the boot perishes....
(thanks Ian)
Page created in 0.113 seconds with 20 queries.
