Author Topic: Love of Cars C4  (Read 11676 times)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Love of Cars C4
« Reply #30 on: 27 April 2014, 19:58:03 »
Scimitar. Where they managed to add overheating to its attributes.
I sense that you're not a fan of the legendary essex lump, Nick. ::) ::) ;D ;D
It's only legendary because any competitors were even worse. BMCs C-series for instance.
kevinp58
  • kent
    • 2002 3.2 elite
Re: Love of Cars C4
« Reply #31 on: 27 April 2014, 22:26:43 »
Correct the superior Essex lump  :y :y
Superior to what?
A boat anchor? Crawling on your hands and knees across broken glass? Mopeds?
superior to the cologne engine :y
Is it? Really? Neither has much to recommend it; it's more a case of deciding which set of 'characteristics' is the least bad.
An Essex weighs a ton, has bottom end torque - which is a polite way of saying it's a wheezy, asthmatic boat anchor - a valve train that's comically weak, is crap on fuel and is expensive to rebuild.
A Cologne weighs a ton, revs well - which is polite way of saying it's a gutless boat anchor - a valve train that's comically weak, is crap on fuel and expensive to rebuild.
The best thing you can do with either is to reunite them with their chain, and put them back into their natural environment under a boat.
I must add that I do like the 12v 2.9 for a road car, and the Cosworth is good when attached to a manual gearbox.
At least the could have decent head work done to them and safely turbo'd unlike the omega V6  :-X neither had timing BELTS that had to be changed every 40,000 miles.
  • Chatham, Kent
Re: Love of Cars C4
« Reply #32 on: 27 April 2014, 22:38:20 »
They both have nylon timing gears which can quite easily break every 40k miles. Not to mention the utterly ineffective 'self-locking' rocker arm bolts that loosen if you use the engine hard.
I'm not a fan of either engine.
kevinp58
  • kent
    • 2002 3.2 elite
Re: Love of Cars C4
« Reply #33 on: 27 April 2014, 23:07:32 »
Never had a problem with mine and I deffinately drove it hard. :-X
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Love of Cars C4
« Reply #34 on: 28 April 2014, 09:31:23 »
Don't forget the bloody useless Allen key drive for the oil pump on the essex lump which used to fail quite regularly :-X
other rides
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Re: Love of Cars C4
« Reply #35 on: 28 April 2014, 10:18:13 »
Thought they did a good job with the series 1 Landrover last night.
omega squared
  • london area
    • 335i/race car/2 x V6 est
Re: Love of Cars C4
« Reply #36 on: 28 April 2014, 11:22:37 »
I thought so too, have not seen this program before but seemed quite good
nothing tows better than an Omega estate in this price range
Re: Love of Cars C4
« Reply #37 on: 28 April 2014, 16:28:31 »
I thought it was pretty poor, the quality of his welding on the chassis was not up to scratch either!
kevinp58
  • kent
    • 2002 3.2 elite
Re: Love of Cars C4
« Reply #38 on: 28 April 2014, 16:38:59 »
I have seen pigeons do a better job  ;D but it did look nice at the end though :y although they could show more of the renovation it is nice to see the history of the vehicle they are doing.  :y
Re: Love of Cars C4
« Reply #39 on: 04 May 2014, 21:00:27 »
Ah the Stag  :-* Those uprated radiators were built for a reason , to stop overheating so what they on about  ::) :(
Re: Love of Cars C4
« Reply #40 on: 04 May 2014, 21:05:03 »
They were suggesting that the cooling system was OK but that the 1970's BL workforce wasn't. ::) ::) ::)
Four words......Quality control and BL. ::) ::) ;)
Re: Love of Cars C4
« Reply #41 on: 04 May 2014, 21:10:18 »
Sabotage  :-\ Maybe they werent aloud enough fag breaks  :(
Olympia5776
  • Ireland
Re: Love of Cars C4
« Reply #42 on: 05 May 2014, 11:22:23 »
I missed the LR programme last week but watched last nights episode.
They pursued the much maligned stag's shortcomings with verve at every opportunity from condemning the condition of the car as bought ( why buy it then ?)  through to a peculiar road trip with a constantly unfunny Gene and a lifelong unfunny and weird Alexie Sayle who hadn't even owned a Stag . They lambasted the car for breaking down again in London and when informed that it was a mere battery they , in their petrolhead wisdom, elected to continue to Paris without changing such a simple component . When in France he called his mate to say that the Stag was true to form and he would be getting the train back , what a load of Shtie .
Cursed the engine when on test the viscous coupling failed , was it new ? , and then informed the world that in fact that there NEVER was anything wrong with the engine cooling design and that the fault lay at the door of production for not bleeding the cooling system correctly in the first place . Really !
I found it very irritating ...........again.
Re: Love of Cars C4
« Reply #43 on: 05 May 2014, 11:28:48 »
There does not seem any passion for the cars at all  >:(
I mean that so called mechanic ! Ham fisted and no patience !!
Very annoying .
Re: Love of Cars C4
« Reply #44 on: 06 May 2014, 00:37:12 »
And insisted on trying to start a car with a dodgy battery with full beam headlights on........... :-X
Mind, the finished result looked nice, but no suggestion of money spent.............. ::) ::)
Pages: 1 2 [3] 4  All   Go Up
