Author Topic: MV6 2.6 Auto breaking  (Read 17374 times)
Re: MV6 2.6 Auto breaking
« Reply #15 on: 23 April 2014, 18:56:03 »
Do you still have the two plastic hockey stick stylee coloured trims from under the headlights by any chance?  If so, I'll have them thanks.
Also, know it's not on this car, but looking for centres for facelift elite rims. A couple of mine now AWOL!  Thanks.  :y
PM sent Broocie :)
« Reply #16 on: 23 April 2014, 18:59:38 »
As per the linked to "sale" ad. Nav system has been tried with a later disc and all working perfectly 8)
« Reply #17 on: 23 April 2014, 19:28:01 »
Whats the condition of the Electrical plug at the throttle body,please Rob ? as still looking for that and as much loom that can be cut off to the cam cover. :y
Just waiting for a member to get back to me about the engine Andrew, unsure as to whether he needs the engine loom :-\
« Reply #18 on: 23 April 2014, 19:47:38 »
Are the 2 parts of the black skuttle cover in tact?
Possible to post, or a non-starter?
Steve
Both good Steve. Posting isn`t a problem
chrisgixer
« Reply #19 on: 23 April 2014, 20:50:52 »
Pm sent re suspension.
« Reply #20 on: 23 April 2014, 21:01:59 »
« Reply #21 on: 23 April 2014, 22:06:21 »
Petrol filler flap? :y
« Reply #22 on: 24 April 2014, 14:57:14 »
1st class postage is going to cost £3.20 James due to size restriction with Royal Mail (25mm max thickness for "large letter")
b4ndit
« Reply #23 on: 24 April 2014, 19:02:20 »
Rob,
have you a drivers side complete mirror please if so how much including postage to ch4 8ea
thanks
terry :y
« Reply #24 on: 24 April 2014, 21:04:52 »
Rob,
thanks
terry :y
PM sent Terry
b4ndit
« Reply #25 on: 24 April 2014, 21:34:16 »
And replied thanks :y
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #26 on: 26 April 2014, 18:22:43 »
Hi Rob, what condition are the MV6 door cards in? I've just managed to put a tear in my offside rear and could do with a nearside front too, so I figured a replacement set might be in order. Cheers :)
PM with your requests.
« Reply #27 on: 26 April 2014, 18:34:10 »
Usual wear marks Dan but all four + the other "silver" bits (centre surround, ashtray, cointray) may be going in mine :)
humbucker
  • Cambridgeshire
« Reply #28 on: 28 April 2014, 13:13:51 »
Ok Rob, thanks for the heads up. Incidentally, the silver bits are fine on mine - it's the fabric that's torn. Are the facelift MV6 and Elite doorcards the same (other than the wood/alu insert?). Might be easier for me to get Elite door cards and swap the trim.
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #29 on: 30 April 2014, 12:28:43 »
light switch assembly ??    specifically front fog light switch is the urgent thing…..    mine has suddenly decided to fail and is stuck on……
