Author Topic: 2.2 rear brake pads  (Read 4625 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
2.2 rear brake pads
« on: 21 April 2014, 10:10:21 »
Are these the same as a 2.0 as mine are worn and I have a spare set from when I had my 2.0.
Don't want to start job only to find out they don't fit.
Cheers Ian
chrisgixer
Re: 2.2 rear brake pads
« Reply #1 on: 21 April 2014, 13:20:13 »
See what others say but I would think so, provided the discs are the same re vented or non vented for the pin lengths.
I'm unsure as the 4 pots had a calliper change at some point. :-\
« Reply #2 on: 21 April 2014, 13:39:59 »
Same across the range from Carlton/Senator B onwards :y
Only a twenty minute job to change them :y
plym ian
  • Plymouth, Devon
« Reply #3 on: 21 April 2014, 14:23:07 »
I know did my old ones super quick how easy is it to check Hand brake shoes while I'm there?
« Reply #4 on: 21 April 2014, 14:29:07 »
About an hour per side, depending on how easily they come apart/refit :y
It's one of those jobs, if all goes to plan, then they're a doddle, but... ::)
plym ian
  • Plymouth, Devon
« Reply #5 on: 21 April 2014, 15:54:43 »
I know exactly which way mine will go :(
badmuver
« Reply #6 on: 21 April 2014, 16:08:09 »
i started mine then got hacked off with them, next time i will finish it  ;D
plym ian
  • Plymouth, Devon
« Reply #7 on: 22 April 2014, 15:11:32 »
Did the pads today bloody took 1hr on drivers side just couldn't shift one of the pins holding pads in. Even contemplated changing calliper at one point :)
On passenger side disc was quite rusty on rear of it why is this?
« Reply #8 on: 22 April 2014, 15:12:49 »
About 13 years of road crap and probably never been changed  :y :y
plym ian
  • Plymouth, Devon
« Reply #9 on: 22 April 2014, 15:50:12 »
Nowt to worry about then :)
They still look a good thickness
« Last Edit: 22 April 2014, 15:52:00 by plym ian »
« Reply #10 on: 22 April 2014, 15:53:24 »
Sticky piston/pad more like :y
« Reply #11 on: 22 April 2014, 16:03:49 »
Both front and rear don't really wear well on the inside, the front discs corrode really badly on the inside, even with daily use.
Front:
Rear:
Not a sticking piston either, standard normal daily use. These were from an auto, so more than say a manual.
Number of people have had exactly same as above
plym ian
  • Plymouth, Devon
« Reply #12 on: 22 April 2014, 17:27:40 »
That's what they look like. As long as it stops it's ok ;D
« Reply #13 on: 22 April 2014, 17:31:07 »
If both sides of the car are the same then all well and good... but the suggestion was that the inside of one disc was rusty, which suggests a problem ::)
plym ian
  • Plymouth, Devon
« Reply #14 on: 22 April 2014, 18:25:16 »
There was a little bit on rear of drivers Side but not as much as passenger side. Should have taken piccy :)
And I cut my arm on back plate :'(
