Author Topic: Car Broken Down  (Read 5381 times)
downsmen
  • Kent
    • 2.5 V6 Elite Estate
Car Broken Down
« on: 21 April 2014, 13:36:56 »
Hi
I just got home after the car breaking down :(.
I was driving along at about 25 when it just stalled and then wouldn't start. after about 45 min waiting for the AA man to arrive it started first time and then run for about 10 min then stalled again.
Got home after being towed home and he had a look at the car thinking it could be the fuel pump or relay, after about 30 min he thinks there is a intermittent fault in the ECU.
This happened about a month ago but has been fine since till today. Any ideas.
Many Thanks
Re: Car Broken Down
« Reply #1 on: 21 April 2014, 13:38:01 »
Classic crank sensor :y
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Car Broken Down
« Reply #2 on: 21 April 2014, 13:42:40 »
Can confirm taxi al's diagnosis, replace the crank sensor with a gen gm part only, pattern will fail again soon. there is a guide in the maint section on how to do it.
Gary. :y
Jaguar XJ6
downsmen
  • Kent
Re: Car Broken Down
« Reply #3 on: 21 April 2014, 13:46:00 »
Is this easy to do? and how much approx.
ffcgary1
  • Mitcham,Surrey.
Re: Car Broken Down
« Reply #4 on: 21 April 2014, 13:51:10 »
fairly easy, have a read of the guide mate, not sure of the currant price of the crank sensor.
Jaguar XJ6
downsmen
  • Kent
Re: Car Broken Down
« Reply #5 on: 21 April 2014, 13:55:25 »
Just had a look this looks easy I shall order a new one tomorrow.
Thanks for your help.
Re: Car Broken Down
« Reply #6 on: 21 April 2014, 14:58:06 »
have you done a paper clip test? You'll likely get a code 19 ......... ie crank shaft sensor.
powerslinky
Re: Car Broken Down
« Reply #7 on: 21 April 2014, 19:23:21 »
As yours is a 2.5 be aware there are 2 types for this engine . VX dealers often supply the wrong one .
Look in the FAQ section  . .  there is a good write up there  under "Crank sensor variants" that explains the difference  :y :y
as advised by others  . . .Genuine only  for this part  ;)
nothing worse than ordering the part & finding it is incorrect when it arrives
woolley11
  • York
    • 3.0 MV6 auto
Re: Car Broken Down
« Reply #8 on: 21 April 2014, 20:07:50 »
Very much crank sensor - done mine a while ago and no further probs.
Tip: Don't spend a heap of time removing old one - just tie it up out the way. If Haynes manual followed you'll be all day for a 10 minute job !   ;)
Omega 3.0 MV6 pfl
BMW Alpina B10 3.3 Touring
VW Mk1 Golf GTi Campaign, Triumph Dolomite Sprint
ffcgary1
  • Mitcham,Surrey.
Re: Car Broken Down
« Reply #9 on: 21 April 2014, 21:01:46 »
yep cut the old plug off and the sensor off as well, leave the old cable in place.
Jaguar XJ6
downsmen
  • Kent
Re: Car Broken Down
« Reply #10 on: 21 April 2014, 21:23:38 »
Cheers guys  :) as usual you are all very helpful and knowledgeable.
Thanks again
Re: Car Broken Down
« Reply #11 on: 22 April 2014, 11:01:58 »
AA spot on again with their diagnosis   ::)
downsmen
  • Kent
Re: Car Broken Down
« Reply #12 on: 22 April 2014, 12:08:52 »
Just ordered a new one £71.52 :(or something like that, will be here tomorrow so should be back on the road by tomorrow afternoon.
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
Re: Car Broken Down
« Reply #13 on: 22 April 2014, 21:54:15 »
Yes, sounds about right. You'll never get the old cable out!
The maintenance guide is very good.
Work is the curse of the drinking classes (Oscar Wilde)
Re: Car Broken Down
« Reply #14 on: 23 April 2014, 01:40:52 »
Why not? - cut ends off and it will easily pull through ::)
