Author Topic: Omega 0-60 test: will these two factors make a difference  (Read 5014 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Omega 0-60 test: will these two factors make a difference
« Reply #15 on: 21 April 2014, 19:19:26 »
Ps...
I've been putting it in 'D' and in sports mode. Should I perhaps do it in '2' andin sports mode?
Aye you will notice the difference , mite need a change of pants if you floor it  ;D Oh and keep an eye on the fuel gauge  :(
 ;D ;D ;D
You reckon that will be faster?
RIP Paul Lovejoy
« Reply #16 on: 21 April 2014, 19:22:38 »
Ps...
 ;D ;D ;D
Yep  :y Well it is in the 3.0 , never tried it in a 2.5 as never owned one  :-\
Webby the Bear
  • Northampton
« Reply #17 on: 21 April 2014, 19:24:58 »
Right, I'm off to try all this without the spares...... on my private track of course  :y
RIP Paul Lovejoy
« Reply #18 on: 21 April 2014, 19:47:51 »
Yourve been gone too long now  ::) Stop thrashing it  ;D
martin42
« Reply #19 on: 21 April 2014, 20:25:46 »
He ran out of petrol lol
« Reply #20 on: 21 April 2014, 20:34:58 »
Maybe changing his pants  ::) ;D
Webby the Bear
  • Northampton
« Reply #21 on: 21 April 2014, 20:44:02 »
In the end couldn't do it.... my private track was busy  ::)
As I'm going to drive it in '2' and thenget it to 60 will it get to the red line and sit there until I get to 60? Don't really fancy staying ON the red line for long  :-\
RIP Paul Lovejoy
« Reply #22 on: 21 April 2014, 20:47:58 »
Dont forget the gearbox learns to the way you drive , at least it does when it works  ;D
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #23 on: 21 April 2014, 21:24:55 »
There will be many variables when you do a 0-60mph time that will affect it slightly, like ambient air temperature, humidity, how warm engine, engine oil, gearbox and diff oil are. Tyre pressures and how hot you tyres are as this will marginally affect effective tyre diameter, all up weight etc., etc.
A way to eliminate all of these factors is Beachy Head, it is very good for a one off 0-120mph time. ::) :P ;D ;D
Webby the Bear
  • Northampton
« Reply #24 on: 21 April 2014, 21:52:47 »
Thanks Rods. So based on my initial post with my varied times you wouldn't be concerned that it doesn't do 9.5 bang on every timeand in fact gets slower some times?
RIP Paul Lovejoy
2woody
  • Northumberland
« Reply #25 on: 22 April 2014, 12:39:59 »
EGR is part of a strategy to reduce NOX emissions ONLY and of no use for anything else. In the UK, MOT stations can't even measure NOX, so it remains part of the type approval of the vehicle when new.
inducing exhaust gas into combustion does affect the flame properties - basically it reduces peak combustion temperatures, which is where the NOX is formed. But it also reduces performance quite markedly.
EGR is used only when needed during the EC drive-cycle used for the type-approval test. Mainly during the cold-start part. Most of the EGR use during normal running is to keep the system working and not for an emissions purpose.
hope this helps
Webby the Bear
  • Northampton
« Reply #26 on: 22 April 2014, 12:56:00 »
Thanks 2Woody, appreciate that.
On to the 0-60 results does it make sense about why the figures are different? Would you be concerned i had a performance issue (no pun) with those fluctuating times albeit max fluctuation being 1 second??
RIP Paul Lovejoy
« Reply #27 on: 22 April 2014, 13:13:25 »
If you're measuring with a speedo and stopwatch I think any variation can be put down to the inaccuracy of the measurement method. I think you're doing well to get a spread of only a second, TBH.
Webby the Bear
  • Northampton
« Reply #28 on: 22 April 2014, 14:09:18 »
Thanks Kev,
i shan't be concerned with it anymore :)
RIP Paul Lovejoy
