Author Topic: very rusty  (Read 10928 times)
davieboy0312
  • wishaw
    • 3l V6 saloon
very rusty
« on: 21 April 2014, 21:02:27 »
hi guys
just stripped down my new omega ready for sand plasting and painting but I have came across LOADS of rust
I have rust in front crossmember (got a new one), both rear arches (got new ones) both sills (got new ones) but have rust at offside under rear seat at arch, in the boot on offside corner and same on near side
but on the passenger side chassis leg just in front of the bolt for the front subframe is a 2 inch hole.  what thickness of steel should I use to repair the chassis leg and bits on the floor??
just in front of the bolt furthest back, you can see it right behind shock absorber
thanks in advance and sorry if this has been discussed before
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: very rusty
« Reply #1 on: 21 April 2014, 21:14:30 »
blimey, has that ever lived by the sea, thats a lot of tin worm you have there.
Jaguar XJ6
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: very rusty
« Reply #2 on: 21 April 2014, 21:16:08 »
I know its got loads sills especially. but never noticed til taken sill covers off
sills not dear though neither was rear arches but cross member was 160 quid!!
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: very rusty
« Reply #3 on: 21 April 2014, 21:16:18 »
I sadly cant help with the repair as I'm not a welder (yet) but would be interested in pics of this if you can get them as I too havesome rusting issues and would be good to compare
RIP Paul Lovejoy
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: very rusty
« Reply #4 on: 21 April 2014, 21:17:34 »
that's cool I got the parts the welder and I can weld just unsure of steel thickness for chassis leg, I get pics up tomorrow of the rust
Webby the Bear
  • Northampton
Re: very rusty
« Reply #5 on: 21 April 2014, 21:19:02 »
Awesome, cheers Davieboy  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
Re: very rusty
« Reply #7 on: 21 April 2014, 21:47:43 »
Wow that chassis legs rotten. is that in the engine compartment? or sticking out the back
RIP Paul Lovejoy
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: very rusty
« Reply #8 on: 21 April 2014, 21:48:57 »
when you take passenger wheel off and take shocker out the way you see this
Webby the Bear
  • Northampton
Re: very rusty
« Reply #9 on: 21 April 2014, 21:50:50 »
Got ya.
These are mine in the sameplace....
And I thought mine were bad  :o
RIP Paul Lovejoy
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: very rusty
« Reply #10 on: 21 April 2014, 21:53:08 »
in your pic you can see last bolt in subframe just in front is the rusty hole
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: very rusty
« Reply #11 on: 21 April 2014, 22:32:01 »
so my question is should I buy 2mm thick to repair chassis leg or is that overkill?
« Last Edit: 22 April 2014, 00:25:49 by dbug »
andyc
  • Norfolk
Re: very rusty
« Reply #13 on: 22 April 2014, 00:56:33 »
If is a double skin then you will need 2mm for the inner and 1mm for the outer, just finished the inner rear chassis leg on the Senator
Rot cut out of the old leg
New Section
And finished. just need to clean back the welds then the outer can be made
Cheers
Andy
Thetford. Norfolk
Webby the Bear
  • Northampton
Re: very rusty
« Reply #14 on: 22 April 2014, 07:37:33 »
Andy, nice pics. Is it a subframe out job or can you get around it? (don't know anything about welding until symes master class
RIP Paul Lovejoy
