Author Topic: re.wheel lock key lost.  (Read 2509 times)
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
« on: 23 April 2014, 09:14:33 »
hi and thanks to everyone for your wellcoms. i have had the car 1 weeks .have a flat tyre and cant seem to find the wheel nut key any where. is there a place on the omega that it is stored. or is it gone in which case help what do i do  :(
Re: re.wheel lock key lost.
« Reply #1 on: 23 April 2014, 09:36:40 »
..... is there a place on the omega that it is stored.
Spare wheel well? With the jack? Still in a drawer at the previous owner?  ::)
You might have luck with something like these  :-\
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #2 on: 23 April 2014, 10:37:11 »
Try all cubby holes - glove box left and right, and rear of boot pockets left and right, door pockets, etc. If no joy, ttry to trace previous owner and ask him.
I once bought an Omega in auction at Witney, found it had locking wheel nuts and no key that I could find. I found previous owners details in documents, rang him, it turned up in his wife's handbag. I drove there (only in Bath, 10 miles away) and he gave it me together with a set of bulbs.
That tool might work ( I wonder how though), otherwise a thread a month or so ago described how it can be removed by welding a big nut to it.
 Those security nuts are a pain. First thing I do on buying a used car is remove them and replace them with proper wheel nuts.
Phil
« Reply #3 on: 23 April 2014, 12:55:58 »
Alternatively check the paperwork/ manual that came with the car and it might have the number of the key in there.
Generally a small square of white card with sticker and 3 figure number and the GM part number for the type of locking nut
If its a Vxl key/ nut then pop into the stealers with the V5, some form if ID and £40 and they will order you a new one which will take 2-3 days to arrive
mickyboy123
  • brighton
  • hi
« Reply #4 on: 23 April 2014, 13:50:24 »
thanks for all your help panic over. found on oposite side to sparre wheel next to first aid compartment. its own little place for the jack and a box containing spare wheel nuts and key. phew. :y
« Reply #5 on: 23 April 2014, 13:52:03 »
Now throw the locking bolts away and replace with standard ones  :y
Far easier and won't easily round off!  :)
