Author Topic: Scary episode  (Read 2883 times)
andrew38
  • Farnborough, Hampshire
  • Insignia 2.0Cdti 163
Scary episode
« on: 26 April 2014, 11:16:56 »
Well the car has been faultless for my ownership but just now was driving along and then engine cut out, luckily managed to coast into a layby, car would crank but not fire. left it for 5 mins cranked it and it started fine, then did the same again 10 mins later by which time I was nearly at my destination. Left it a couple of minutes and it restarted as before. Not a nice experience, has anybody else had this occur. Any advise appreciated as always.
martin42
Re: Scary episode
« Reply #1 on: 26 April 2014, 11:17:44 »
Crank sensor
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Scary episode
« Reply #2 on: 26 April 2014, 11:31:02 »
If it's a V6 I'd agree with the above. Classic crank sensor systems.  :y
ted_one
Re: Scary episode
« Reply #3 on: 26 April 2014, 11:49:02 »
Had the same problem a few months ago,replaced the crank sensor.......problem solved :y
al brown
  • alton, hants
    • Rusty 97 3l estate
Re: Scary episode
« Reply #4 on: 26 April 2014, 11:55:38 »
As always, check for codes first. It does sound like a crank sensor as they fail when they get hot then work fine when they have cooled, hence the cutting out and restarting after a bit.
If it is the crank sensor make sure you route the new wire away from the exhaust.
Be worth adding the car details to your details.
If it aint broken, you aint trying hard enough
YZ250
Re: Scary episode
« Reply #5 on: 26 April 2014, 11:56:09 »
If it's a V6 I'd agree with the above. Classic crank sensor system.  :y
Or even Symptoms. I usually double check what I've written but that one slipped through the net.  ::) ;D
I'll try again.  ;D
Classic crank sensor symptoms.  :y
andrew38
Re: Scary episode
« Reply #6 on: 26 April 2014, 12:03:29 »
Thanks for all the replies and assistance. Ordered a new genuine sensor from Vauxhall be delivered on Wednesday.
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
Re: Scary episode
« Reply #7 on: 26 April 2014, 20:29:57 »
It's sounds for all the world like the crank sensor but I suggest you do the pedal trick and post the codes on here just to be sure.  :y
http://www.omegaowners.com/forum/index.php?topic=90581.0
« Last Edit: 26 April 2014, 20:34:22 by Paddy Flannery »
Re: Scary episode
« Reply #8 on: 28 April 2014, 00:54:52 »
Classic symptom faulty crank sensor - note a faulty crank sensor doesn't always throw a fault code ;)
Re: Scary episode
« Reply #9 on: 28 April 2014, 18:38:15 »
Pedal trick it to confirm (0335), but sounds like crank sensor.
My first one failed at about 130 (kph, obviously...) just outside Dijon. Most inconvenient ;D
andrew38
Re: Scary episode
« Reply #10 on: 29 April 2014, 13:21:10 »
Mine was at around 50mph and that was bad enough 80mph a different story. If I had thought about this a bit more would have replaced as preventative maintainance like the cambelt.
Page created in 0.022 seconds with 20 queries.
