Author Topic: ABS and TC lights on  (Read 1936 times)
judge_dredd65
  • Selby, North Yorkshire
    • Omega 3.2 MV6 ,Irmscher
« on: 27 April 2014, 10:15:56 »
Hi all,
My ABS and TC lights have just suddenly come on and stayed on. When you first start the car they do not come on till you move off. The speedo is still working. Is this just going to be one of the abs sensors?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: ABS and TC lights on
« Reply #1 on: 27 April 2014, 11:01:44 »
Are all the indicator lights on the gearbox selector working as you move the gear stick ?
Best do the peddle trick and put the codes up here  :)
« Reply #2 on: 27 April 2014, 11:17:43 »
Pedal trick & paper clip trick just does engine codes  :)
judge_dredd65
« Reply #3 on: 27 April 2014, 11:37:21 »
yes all the indicator lights are working on gear selector.
my fault codes are
10 4 3 10
10 4 2 10
10 3 4 10
« Reply #4 on: 27 April 2014, 12:37:26 »
my fault codes are
10 4 3 10
10 4 2 10
10 3 4 10
0430/0420 is usual on the 2.6/3.2 (pre-cat)
0340 is cam sensor, very rare to have problems with that on the V6 ???
« Reply #5 on: 27 April 2014, 20:36:25 »
Needs a code reader that can read ABS ECU, ideally.
However, I have seen spurious cam codes through the autobox ecu off kilter, which then upsets the ABS ECU...  ...IME, that only brings on TC light, not ABS one.
« Reply #6 on: 28 April 2014, 00:21:35 »
Probably dodgy abs ecu, although could be a sensor.
