Author Topic: water in spare tyre well  (Read 2983 times)
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
« on: 27 April 2014, 13:10:42 »
hi. i seem to have a small pond in the spare tyre well. does any 1 no how this water is gettin in .the boot mat is a little wet to in that corner.
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
Re: water in spare tyre well
« Reply #1 on: 27 April 2014, 16:32:30 »
Have you looked at the rubber grommet that the wires goes through in the gutter of the boot. That's where I would look first.  :y
Alex W
    • 2000W Facelift 2.5V6 Elit
« Reply #2 on: 27 April 2014, 16:50:33 »
I have had the same problem for some time.
Have a look at the seam between the panels ,usually hidden by the boot lid, above the spare wheel well,near the rear windscreen. Tests with a watering can have shown ingress from there. I have tried applying silicon sealant there a few times, it stays dry for a while but comes back after a few months.
I am now thinking of simply drilling a drain hole at the lowest point in the wheel well to let the water escape.
mickyboy123
  • brighton
  • hi
« Reply #3 on: 27 April 2014, 17:46:41 »
okay thanks for your ideas. i think i will start with the gromet and then investigate the seam may change the boot rubber just to eliminat a new 1 cant hurt .  :y
Alex W
« Reply #4 on: 28 April 2014, 21:05:24 »
Do a simple test with a watering can before buying anything.
Obviously wait for a dry day,dry out the wheel well and stick some paper towel on the walls of the wheel well, I suggest well forward near the panel seam, then with the boot open pour plenty of water from the very corner of the screen for a while, the towel will show you roughly where its coming in.à
mickyboy123
  • brighton
  • hi
« Reply #5 on: 28 April 2014, 21:16:33 »
okay thanx alex ,i will try that in a few days i will let you no the result. thanx agen for your help  :)
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
« Reply #6 on: 29 April 2014, 20:01:51 »
Get into the boot with a good torch while someone else does the watering on the outside.  :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #7 on: 29 April 2014, 22:17:42 »
That's the best way. . . Catch the culprit red handed  :y
RIP Paul Lovejoy
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #8 on: 30 April 2014, 10:09:39 »
Make sure its a GOOD friend though, or you could be in there a long time !!!! ;D
Delroy47
  • Luton
    • 3.2 Elite Estate
« Reply #9 on: 30 April 2014, 15:57:44 »
Now now ;)
Alex W
« Reply #10 on: 30 April 2014, 18:35:46 »
I had to use paper towels because I don't have any friends. I use them for some other stuff too. :y
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #11 on: 01 May 2014, 20:47:47 »
Good advice did the same with another car that I had took it to the car wash locked my son in the boot and refused to let him out until he found the leak  :y
« Last Edit: 01 May 2014, 20:58:14 by Tony H »
