Author Topic: Windscreen surround trim  (Read 3514 times)
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
« on: 28 April 2014, 19:18:20 »
Hello, does anyone know the best way to refit the windscreen surround trim (single one piece)  Mine had to come out recently, and I am struggling to get it back in its channel.
Thanks
The faster you go the bigger the grin.  Trade card user.
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
Re: Windscreen surround trim
« Reply #1 on: 28 April 2014, 20:27:04 »
hi. try soaking the rubber in cooking oil over nite then put sum in the channell. shld slide into place easy. ;D
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #2 on: 28 April 2014, 21:52:48 »
what I do when fitting a new screen to an omega is spray with watered down washing-up liquid and press back into plastic back trim with your thumbs only! don't use a rubber hammer to "tap it in" push til it clicks in, sorted  :y
« Reply #3 on: 28 April 2014, 23:04:13 »
They don't like being refitted more than once :-\
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #4 on: 29 April 2014, 01:53:02 »
When I had mine refitted after screen Change it never clipped back in properly at all. Probable needs new one :)
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #5 on: 29 April 2014, 06:43:33 »
I have changed these screens many times and never used a trim set on them yet the outer trim is reuse able just got to take refitting
« Reply #6 on: 29 April 2014, 09:41:46 »
Pattern ones can be crap...
plym ian
  • Plymouth, Devon
« Reply #7 on: 29 April 2014, 10:40:21 »
It wasn't a pattern one :(
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #8 on: 29 April 2014, 11:39:47 »
If you lube it up properly and push til it clicks it will sit properly. Just push at trim not on glass or you will split screen
slowboy
  • lode
« Reply #9 on: 29 April 2014, 15:33:59 »
phew ;D
RolandL
  • Doncaster
« Reply #10 on: 29 April 2014, 18:18:09 »
Thanks guys, will give your suggestions a try  :y
