Author Topic: Pressure Washer Cleaning Fluid  (Read 3773 times)
Re: Pressure Washer Cleaning Fluid
« Reply #15 on: 04 May 2014, 20:20:23 »
You're still going to have to rub and wipe it, so get the right tool for the job.
My old window cleaner let me into his secret. Fairy.
Reason for pressure washing and cleaning fluid, is it cannot be reached by hand to scrub  ::)
Bird crap right at the top  >:(
« Reply #16 on: 04 May 2014, 21:16:32 »
That's why they make tools for cleaning them. Believe it or not, you're not the first person to have to clean one.
« Reply #17 on: 04 May 2014, 22:29:39 »
Got an extending scrubber thing, still leaving crud there  :(
« Reply #18 on: 05 May 2014, 00:05:10 »
He is the right tool for the job. ;D
And what is your window cleaners secret?
 :-X ;D ;D ;D :y
« Reply #19 on: 05 May 2014, 10:03:18 »
As in not cleaning? Or leaving smear/dirty water marks?
If latter, you use a rubber blade, a bit like a windscreen wiper, to pull the water off, so it doesn't dry in situ. A bit like using a chamois on a car, if that makes sense.
If former, then if rubbing with a fixed sponge doesn't shift it, a toy pressure washer 3m away won't either.
« Reply #20 on: 05 May 2014, 13:34:53 »
Going be point blank range when get pressure washer on it :)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #21 on: 05 May 2014, 13:39:09 »
Just buy half a litre of White Vinegar Window cleaner spray from Poundland, get on your hands and knees and use some elbow grease.
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #22 on: 05 May 2014, 20:23:32 »
I got some Simoniz stuff form Costco yesterday £8 for two 5 liter bottles not tried it yet as I haven't got my pressure washer yet it's in the post
« Reply #23 on: 05 May 2014, 21:36:32 »
Sounds good, will look for it next time i'm in Costco  :)
