Author Topic: Oil cooler plate removal  (Read 9312 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« on: 03 May 2014, 13:35:48 »
Hi all, hope your all enjoying the nice weather!!
Having a go at replacing my leaking oil cooler. Down to the cooler plate. All bolts undone, encouraged the movement of the pipes, but can't actually get the plate out from between the "V"
I take it there is a knack/technique??
Any help would be appreciated.
TIA :y
AKA - Mr Bracket
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: Oil cooler plate removal
« Reply #1 on: 03 May 2014, 13:40:07 »
think there is a how to on here for it
http://www.omegaowners.com/forum/index.php?topic=90596.0
« Last Edit: 03 May 2014, 13:42:48 by davieboy0312 »
blackviper90210
« Reply #2 on: 03 May 2014, 13:43:03 »
There is a guide for the oil cooler removal which I'm following, but struggling to get the plate out between the "V" :(
AKA - Mr Bracket
blackviper90210
« Reply #3 on: 03 May 2014, 13:44:17 »
The plate is free moves fore and aft but can't seem to lift it out :-[ :-[
AKA - Mr Bracket
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #4 on: 03 May 2014, 13:45:24 »
when I had to do mine I pushed plate all the way to passenger side while lifting at drivers edge bit tight but did come out
blackviper90210
« Reply #5 on: 03 May 2014, 13:49:38 »
Cheers for that, I'll try that now :y
AKA - Mr Bracket
blackviper90210
« Reply #6 on: 03 May 2014, 14:07:46 »
Just tried it again, no joy >:(
It's literally mm too big, or so it seems. It catches at the top lip of the "V". Why did I start this??
Should know better than to play at being a mechanic ;D ;D
AKA - Mr Bracket
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #7 on: 03 May 2014, 14:14:13 »
it does seem big for the hole but trust me it does come out that way try all the way to drivers first then out. I remember it was a total breast to come out but it comes
blackviper90210
« Reply #8 on: 03 May 2014, 14:16:12 »
Cheers for the encouragement mate, much appreciated. Just come in a for a cuppa as I got the hammer out of the tool box, lol. Thought at that point before I use it to chill for 5  ;D ;D
AKA - Mr Bracket
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #9 on: 03 May 2014, 14:21:10 »
You have to line up the cut outs on the plate with the rest of the obstruction, then it just lifts out.
blackviper90210
« Reply #10 on: 03 May 2014, 14:23:35 »
You have to line the cut outs up on the plate with the rest of the obstruction, then it just lifts out.
Cheers Zirk, be  trying that too.  As I'm getting slightly peeved. Having a break from it and going to clean the inlet manifold, replacement oil cooler and plenum. I'll have another go after, probably come straight out, but not holding my breath, lol
AKA - Mr Bracket
amba
  • Medway towns
    • German V6
« Reply #11 on: 03 May 2014, 14:35:39 »
Siily question but I assume you have undone the 2 large brass nuts that hold the plate to the cooler body ? ;)
Plate will require aligning with the cutouts in the V and as you lift one side the other will give you the extra space to wiggle it free.
blackviper90210
« Reply #12 on: 03 May 2014, 14:58:16 »
There's never a silly question when it comes to mechanics with me mate, lol.
All bolts undone, and the plate is free but I just can't seem to get it out from between the "V"
Just going to give it another go now I've calmed down a it  ::)
AKA - Mr Bracket
blackviper90210
« Reply #13 on: 03 May 2014, 15:26:11 »
OK, just been out to have another go...... The light bulb has just flickered as reading your post. :-[ :-[
The 2 large brass bolts are not undone. Just realised how bloody thick I am today. My issue now is not having a socket big enough, that'll teach me for not reading the instructions thoroughly before starting!
Then to add insult to stupidity, I've managed to lose an inlet manifold rubber seal..... That's my luck  ::)
AKA - Mr Bracket
zirk
  • Epping Forest
« Reply #14 on: 03 May 2014, 15:31:15 »
Mole Grips, Adjustable Pipe Wrench or worse case Screwdriver at an angle and Hammer off till finger loose.  ;)
