Author Topic: P1625 ? Anyone ever sorted it  (Read 1710 times)
omegod
  • liverpool
    • 2017 Seat Ateca
« on: 05 May 2014, 10:02:00 »
Not my week for gearboxes!
Had issues for a while and changed the 2-3 solenoid but it's still not wanting to drive particularly and getting worse. Code reader that can't be named shows P1625 (2) NP Internal Power Control Final Stage Low input.
Blue plug is secure in the engine bay, guessing next course of action is replace the pressure solenoid and check all the connectors are secure then maybe replace gearbox ecu. Fluid has been done a few weeks ago! I think James had a similar issue so input welcome :y
omegod
  • liverpool
    • 2017 Seat Ateca
Re: P1625 ? Anyone ever sorted it
« Reply #1 on: 06 May 2014, 17:58:19 »
FYI pressure solenoid from the scrappy sorted it ! been playing up for ages so quite the different car now
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #2 on: 09 May 2014, 17:21:19 »
How big a job was that?
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #3 on: 09 May 2014, 19:57:27 »
Small sump off 10 x 10mm bolts
catch the fluid in a clean bowl
undo 1 x 11 mm bolts
pop off connector and remove solenoid , pop new one in.
Reverse to reassemble with a smidge of silicone on the sump and put the fluid back in! ( I had not long changed it )
Can be done in 30 mins  :y
