Author Topic: alternative tin worm repair  (Read 17516 times)
Re: alternative tin worm repair
« Reply #30 on: 30 May 2014, 18:20:11 »
You can buy inert primers to suit the composition of the epoxy repair :y most epoxy manufacturers will produce/sell summat specific to their products...
« Reply #31 on: 30 May 2014, 18:32:13 »
thanks Al :y
« Reply #32 on: 30 May 2014, 21:39:50 »
seems like I choose a "perfect day" no dust around ;D ;D ;D :D
thats my city today ???
http://sozcu.com.tr/2014/gundem/gokcek-ankaraya-deniz-getirdi-521107/
« Last Edit: 30 May 2014, 21:44:01 by cem »
« Reply #33 on: 30 May 2014, 21:41:46 »
Guessing you live on a hill then :y
« Reply #34 on: 30 May 2014, 21:44:49 »
yep.. there is small hill.. so no flooding problem :y
« Reply #35 on: 31 May 2014, 19:21:36 »
although had some problems because of hurry for rain finally today painted it
just after I finished it rain started >:( but it was covered already :P
result better than I expected.. tomorrow will wet sand 1500 , 3000 trizact then polish..
« Reply #36 on: 31 May 2014, 19:32:56 »
and a word of note for home diy painter:  for metallics paint a part completely unless there is specific reason not to..   but if you have to paint partially , color paint the problem area only (not total) than spray shortly around  far and tiny with fast movement  then advance the laquer a bit further than the painted area (but dont reach the masking limits or you will have a stair of paints).. and than spend your life sanding ;D ;D
« Last Edit: 31 May 2014, 19:34:38 by cem »
« Reply #37 on: 02 June 2014, 18:51:27 »
and the painting finished today (I painted twice , didnt like it.. removed new paint and blocked sanded again)
need to block sand heavily (wet 240)  as surface was awful like a geography map.. lots of bondo :(
epoxy primed as usual.. sanded with wet 600
and painted .. only one spot a very small fly passed in front of my satajet while spraying  ;D  and nosed dived into laquer >:(
« Reply #38 on: 02 June 2014, 20:07:07 »
Them fly just wait till you start spraying dont they  >:(
Are you not fed up with sanding yet Cem  ;)
« Reply #39 on: 02 June 2014, 20:19:31 »
I have fed up long time ago..  :-\ but a good paint is  % 99.999 sanding % 0.001 painting.. what can I do :-\
and I hate sanding very low parts , you cant see and your belly will have pain within short time
Keith ABS
  • Maldon Essex
« Reply #40 on: 02 June 2014, 20:21:04 »
  My Monza was treated to two coats of epoxy primer as the paintshop decided to do a bare metal job on the whole car, lots of sanding!
Keith B
« Reply #41 on: 02 June 2014, 20:24:01 »
and the hardest point is the passage/intersection between old and new laquer.. you use the highest number (1500-2000) -old- sand paper and carefully arrange the passage/intersection.. for few cms you work for more than an hour (or two) carefully not to damage the old laquer..
normally I dont do these kind of painting.. but friend will sell his car and dont want whole parts to be painted :-\
ps: will post the final pictures after polishing
« Reply #42 on: 02 June 2014, 20:24:41 »
Keith B
sometimes its much better if you cant trust the lower layers :y
« Reply #43 on: 02 June 2014, 20:26:41 »
Keith B
Epoxy primer seems to be the way to go nowadays , should last forever  :y
« Reply #44 on: 02 June 2014, 20:29:12 »
Keith B
very good material.. the only drawback is it hides the small scratches and dings (or imperfections) because of its color.. so after sanding you have to apply 2 coats of original metallic color without laquer - too see imperfections left
but one good side it keeps window 72 hours :) (glassurite)
ps: I bet very few will understand this "window" ;D
« Last Edit: 02 June 2014, 20:32:25 by cem »
