Author Topic: V6 Spark Plug choice for a 2003 3.2  (Read 5906 times)
Re: V6 Spark Plug choice for a 2003 3.2
« Reply #15 on: 08 May 2014, 09:47:47 »
Thanks for all the replies guys,  :y
So if I order 6 X GM09 9195109 ( twins ) they will fit and work fine ?  :-\
Yes, perfectly fine
LC0112G
« Reply #16 on: 08 May 2014, 14:56:58 »
LC,s use a twin point as a standard plug, loking very similar to the Omega item
They don't. OEM plugs for the LC are NGK BK6E's which are single point.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #17 on: 08 May 2014, 15:06:30 »
both correct. The twins are used to help with the spark as,blown engines, can blow the spark out hence two electrodes.
Hoof'land storeman.
LC0112G
« Reply #18 on: 08 May 2014, 15:34:34 »
Huh? I don't doubt you could use a twin/quad prong in an LC.
I'm saying that the standard (OEM) plug in an LC is single electrode, and it is different to the Omega Item. Vx P/n for the LC is (was) 90393137. SO I'm quibbling with the statement "LC,s use a twin point as a standard plug, loking very similar to the Omega item" which is incorrect in several ways.
« Reply #19 on: 08 May 2014, 15:39:01 »
Two electrodes will make no odds as you only strike the spark across a single electrode at any one time, if the spark is blown out then it will either be to late to do anything and a missfire will occur or the spark will re-establish (and you get a partial missfire).  :y
The ONLY thing adding electrodes does is extend the total electrode life of the plug.
« Reply #20 on: 09 May 2014, 09:41:37 »
Would it cause confusion if I mentioned that I currently have triple electrode plugs in my 3.2? :-X
« Reply #21 on: 09 May 2014, 09:47:18 »
there's always one three  ;D ;D
biggriffin
« Reply #22 on: 09 May 2014, 11:09:29 »
attention seeker ;D
Hoof'land storeman.
« Reply #23 on: 09 May 2014, 14:38:29 »
Did you break one off then?
« Reply #24 on: 09 May 2014, 16:20:07 »
No - ordered them from one of the regular suppliers along with a cam belt kit as the price was right, and Delphi plugs with 3 electrodes duly arrived.
