Author Topic: Crankshaft oil seal leaking  (Read 5600 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« on: 09 May 2014, 09:48:49 »
Just want to make sure, it is the crankshaft oil seal leaking. The oil inside the crank pulley itself is plusgas and not from the engine. All other oil is from the leak. I've added some engine photos as well to help diagnose the leak.
https://www.flickr.com/photos/53447058@N05/14143280515/
https://www.flickr.com/photos/53447058@N05/13956642218/in/photostream/
https://www.flickr.com/photos/53447058@N05/14139950841/in/photostream/
https://www.flickr.com/photos/53447058@N05/13956684060/
https://www.flickr.com/photos/53447058@N05/14139990641/in/photostream/
https://www.flickr.com/photos/53447058@N05/13956608779/in/photostream/
There are other photos on Flickr of the engine. Please feel free to have a look and let me know if you see anything that should be looked at.  :y
Andy A
  • Bristol UK
Re: Crankshaft oil seal leaking
« Reply #1 on: 09 May 2014, 10:29:04 »
Can anyone confirm this is the crankshaft oil seal leaking?
Is it best to buy the VX oil seal or is the one from buypartsby just as good?
http://www.buypartsby.co.uk/details/VAUXHALL/OMEGA/2.2/2003/__/123/OS700/crankshaft-seal/
Thanks
« Reply #2 on: 09 May 2014, 11:06:45 »
Thanks
It certainly looks like it could be from the front crank shaft seal. I'd tend to buy from the dealer, you have more chance of getting a quality seal and as it's not the easiest thing to change you don't want to be changing a cheapo seal again if/when it fails
« Reply #3 on: 09 May 2014, 11:13:20 »
Have you whipped the cambelt cover off to confirm it`s not dripping from camshaft seals?
Andy A
  • Bristol UK
« Reply #4 on: 09 May 2014, 11:17:49 »
Yes, see photo links in my first post  :y
Andy A
  • Bristol UK
« Reply #5 on: 09 May 2014, 11:19:51 »
« Last Edit: 09 May 2014, 11:25:58 by Andy A »
Andy A
  • Bristol UK
« Reply #6 on: 09 May 2014, 11:24:47 »
Thanks
I'll order a VX seal then.  :y Do you know the price?
« Reply #7 on: 09 May 2014, 11:47:04 »
No, but a V6 REAR crank seal was £30-odd .... which for a common lip seal is quite expensive  ???
Andy A
  • Bristol UK
« Reply #8 on: 09 May 2014, 12:34:25 »
That's what I paid for the dif VX oil seal. The cost is all adding up with all the tools needed as well.  :-\
Andy A
  • Bristol UK
« Reply #9 on: 09 May 2014, 13:49:36 »
Anyone know the part number for the VX front crankshaft oil seal for Omega 2.2 petrol manual 2003?
Thanks
Andy A
  • Bristol UK
« Reply #10 on: 12 May 2014, 12:52:57 »
Anyone got the part number for front crankshaft oil seal Omega 2.2 petrol 2003?
Thanks
« Reply #11 on: 12 May 2014, 13:17:12 »
Thanks
Your dealer will  ::)  ::)
Andy A
  • Bristol UK
« Reply #12 on: 12 May 2014, 13:21:41 »
Thanks
Unfortunately they won't give part numbers out.  :(
« Reply #13 on: 12 May 2014, 13:26:03 »
Thanks
I'd try another dealer, as that's very poor  :(
« Reply #14 on: 12 May 2014, 13:26:59 »
Thanks
They'll give you a price though. And as said, if you get from the dealer, you're more likely to get a premium make seal rather than a cheapo Chinese made from elsewhere. The difference in cost between the cheapo & main dealer is offset by the effort involved in changing it for a seal that'll do its job .....  not leak again in a few months.  ;)
« Last Edit: 12 May 2014, 13:29:25 by Andy B »
