Author Topic: 3.2 manual - recommended new flywheel and clutch  (Read 4224 times)
jb
  • bucks
    • 3.2 Elite
« on: 09 May 2014, 20:20:54 »
Need to buy the above ,what recommended makes,suppliers etc pls
Re: 3.2 manual - recommended new flywheel and clutch
« Reply #1 on: 09 May 2014, 20:35:03 »
Luk clutch kit, as cheaper than Vauxhall.
Vauxhall flywheel as half the price of luk one :y
serek
  • huntingdon
    • 3.2 mv6
« Reply #2 on: 09 May 2014, 21:37:03 »
not sure how many miles you have done but I not saw DMF need replacing on omega jet
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #3 on: 09 May 2014, 21:52:07 »
as above :y or fit non dmf flywheel.
Hoof'land storeman.
serek
  • huntingdon
    • 3.2 mv6
« Reply #4 on: 09 May 2014, 21:57:36 »
yep you can buy vectra fly wheel for about £10 on ebay
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #5 on: 10 May 2014, 00:10:20 »
There is a reason they fitted a DMF on an Omega  ;)
biggriffin
« Reply #6 on: 10 May 2014, 06:52:42 »
they did, its a big shock absorber, to help keep the power takeup and delivery smooyh,and also to heip keep some vibration at bay.
what did we do before dmf ???
Hoof'land storeman.
« Reply #7 on: 10 May 2014, 10:28:45 »
Clutches had sprung hubs - not quite as refined, but lighter and more reliable.
If you fit a solid flywheel, make sure you fit a clutch that has a sprung hub. :y
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #8 on: 10 May 2014, 11:12:32 »
And a spacer for the release bearing as the solid flywheel is a lot thinner than the DMF.
serek
  • huntingdon
    • 3.2 mv6
« Reply #9 on: 10 May 2014, 12:51:02 »
you only need spacer if you use C20xe or c20let flywheel,
vectra v6 fly wheel its same size as omega
