Author Topic: Xenons with standard suspension?  (Read 3762 times)
jim351
  • Bognor Regis, West Sussex
« on: 12 May 2014, 19:20:58 »
Hi all, im thinking of replacing my suspension on my 2001 Elite, my question is when i junk the self leveling what do i do about the headlight adjustment? what else do i need to fit to make the headlights adjust with a normal headlight switch?  :y
jim
Re: Xenons with standard suspension?
« Reply #1 on: 12 May 2014, 19:24:03 »
jim
Factory fitted HIDs already have their own levelling system ...... that's why the light switch doesn't have the 1 2 3 that a lesser spec car has  :y
steve6367
« Reply #2 on: 12 May 2014, 19:24:18 »
I am not sure the 2 are related.
Does the Elite not have level sensors on passenger side front and rear for the lights like other models?
Steve
jim351
« Reply #3 on: 12 May 2014, 19:26:21 »
i thought it sorted the headlights out in relation to the suspension? meaning it was controlled together?
jim
« Reply #4 on: 12 May 2014, 19:28:32 »
jim
nope ............ two separate systems  ;)
there are level controller on the passenger side for the headlights, and a third on the rear driver's for the suspension - but 2 systems.
« Last Edit: 12 May 2014, 19:30:38 by Andy B »
jim351
« Reply #5 on: 12 May 2014, 19:32:25 »
well then is it as easy as fitting a standard light switch so the can be adjusted?
jim
« Reply #6 on: 12 May 2014, 19:48:20 »
jim
You're removing the self levelling suspension
the lights are self levelling via their own controller
The two systems are separate from each other
jim351
« Reply #7 on: 12 May 2014, 19:50:54 »
yeah just read through the post again! lol got it thank for the help  :y
jim
chrisgixer
« Reply #8 on: 12 May 2014, 19:51:49 »
jim
Absolutely nothing is required with the headlights. They adjust automatically to the attitude of the car, regardless off what suspension is fitted.
Just remove and re fit the suspension as required, and carry in as normal. There's is nothing to be done with the hid system.
If the headlights are then at the incorrect height, adjust them via the head light adjusters on top of the headlights as normal.
....did I mention, there is no need to fiddle with the head light levelling system.
Suspension levelling and head light levelling are completely unrelated.
jim351
« Reply #9 on: 12 May 2014, 19:54:10 »
jim
ok got that many thanks  :y
jb
  • bucks
    • 3.2 Elite
« Reply #10 on: 12 May 2014, 20:45:44 »
Done it on my elite,no problems
chrisgixer
« Reply #11 on: 12 May 2014, 20:49:36 »
jim
We got there :y
Previous two posts where already up as I was typing, sorry, bit slow. :)
