Author Topic: 3.2 saloon rear diff needed  (Read 6175 times)
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« on: 14 May 2014, 17:24:41 »
As per title pls,
02 plate 3.2 saloon rear diff needed, just the diff no other parts required
must be leak free :y
dads diff has got a whine, and a leaking diff seal from the input shaft.
GARY.
Jaguar XJ6
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: 3.2 saloon rear diff needed
« Reply #1 on: 14 May 2014, 18:00:31 »
I have one removed from my 1996 3.0L estate, don't know if its the same as the 3.2.  It was only removed to fit an LSD not because it was faulty. Its done about 120k miles.  £50 plus carriage, but carriage will be high because it weighs a ton.  Also worth mentioning that I have an LSD from a 3L Carlton at £150 plus carriage.  I was going to see if the Carlton innards would go into an Omega casing.
serek
  • huntingdon
    • 3.2 mv6
« Reply #2 on: 14 May 2014, 18:17:24 »
will fit  :y
ffcgary1
  • Mitcham,Surrey.
« Reply #3 on: 14 May 2014, 22:01:57 »
Thanks for the offer alan,
but as it for my dads car i will hold out for a dedicated 3.2 diff. :y
Jaguar XJ6
ffcgary1
  • Mitcham,Surrey.
« Reply #4 on: 15 May 2014, 23:54:07 »
DIFF RATIO I NEED IS 3.90:1 :y
Jaguar XJ6
ffcgary1
  • Mitcham,Surrey.
« Reply #5 on: 15 May 2014, 23:55:04 »
Sorry did not mean to shout. ::)
Jaguar XJ6
chrisgixer
« Reply #6 on: 16 May 2014, 18:06:33 »
Got one here Gary, 3.9 oe to the car, removed in favour of a 4.22 from a 2.6, then later that was swapped for an LSD. It needs the seals replacing though, as they ALL leak at this age. Ime.
It's probably done about 80k at a guess. Although a tow bar was fitted to the car as it came to me.
Edit to add.
I've yet to see a dry dif on an omega, put it that way. This one, I would say in omega parlance, has a slight leak.
ffcgary1
  • Mitcham,Surrey.
« Reply #7 on: 16 May 2014, 18:37:24 »
what are you looking for it chris,& while it is off the car might be a good time to get the seal done. :y
Jaguar XJ6
chrisgixer
« Reply #8 on: 16 May 2014, 22:02:38 »
Er, having trouble finding it.  :-[
Wondering if it was pert ex'd to 2Woody. :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #9 on: 16 May 2014, 22:19:49 »
I've one from a manual 3.0l which is yours if you collect it. I can check the ratio tomorrow if that would help
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #10 on: 17 May 2014, 00:21:42 »
It will be a 3.7 if its an original fitment.  ;)
« Reply #11 on: 17 May 2014, 02:58:34 »
It's not still attached to the car is it ::)
chrisgixer
« Reply #12 on: 17 May 2014, 06:05:58 »
No not that one, I'll need that. ...to start with.
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #13 on: 18 May 2014, 10:22:40 »
Are the Estate and saloon the same ratio on the 3.2 as mine is an MV6 Estate which has a diff that had a full re-build and has not done a lot of miles since, as the car has been parked up for the past few years. :y
ffcgary1
  • Mitcham,Surrey.
« Reply #14 on: 18 May 2014, 11:55:09 »
if it was a man gearbox then the diff should be the same ratio but there where some exceptions. i know the 2.6 mv6 was the same but needed a man gearbox fitted.
Jaguar XJ6
