Author Topic: Good deal?  (Read 3851 times)
Re: Good deal?
« Reply #15 on: 16 May 2014, 09:24:20 »
Thing is Tunnie, my car has done nealy a thousand miles since I picked it up, so four services in three years simply won't cut it...
In my case it's £1776 for 24 litres of oil (60-300, depending on oil used), four oil filters (20), one air filter (20), one pollen filter (15), four sump plug washers (2), one fuel filter (10), a litre of brake fluid (15-25), 10 litres of 50/50 coolant (25) and four service printouts. Oh and one MoT (45) ::)
Say £462 in parts, the rest in labour and 'free' coffee...
Like I said, not sure if that's good value or not :-\
See your point, my miles would be around 15k a year or so, not 15k every 3 months  :o
Re: Good deal?
« Reply #16 on: 16 May 2014, 16:51:25 »
get a local independent to do it, wont invalidate warranty as long as its done to dealer spec.
Leaning towards that as a plan :y get them to do the services as the car decides it needs them, and deal with anything else as it crops up depending whether a computer is involved or not...
Front discs/pads cropped up at the taxi inspection, parts costing a smidgen more than Vauxhall, so that will be a driveway job as an example :y
Re: Good deal?
« Reply #17 on: 16 May 2014, 17:06:54 »
I found Merc parts quite reasonable compared to Vx and the dealers very helpful!  :y
Re: Good deal?
« Reply #18 on: 17 May 2014, 13:14:23 »
It could potentially impact associated warranties/perks by using indies.  The motor manufacturers have found new ways to work around the laws of the land, and ensure you use their dealers ::)
Re: Good deal?
« Reply #19 on: 17 May 2014, 14:32:45 »
Like 27 years corrosion warranty/Europe wide breakdown cover to name but two perks :-\
