Author Topic: Rotary timing system - new generation  (Read 1022 times)
mkaminski100
  • Basingstoke
« on: 13 June 2008, 10:10:07 »
What do you think about that?
http://www.vagnetix.republika.pl/sil-eng.htm
I am waiting for a test results as an engine with this timing system was built.
Martin_1962
Re: Rotary timing system - new generation
« Reply #1 on: 13 June 2008, 11:37:36 »
Looks like a variant of the rotary valve engines
Sleeve valves would probably flow better anyway
Omegatoy
  • UK
« Reply #2 on: 13 June 2008, 20:17:26 »
it has some merit but, productin and tooling cost would be horrendous and what happens when the system gets a bit of wear in it? noisy?
mkaminski100
  • Basingstoke
« Reply #3 on: 15 June 2008, 17:53:38 »
Guy said that it might last up to 500.000km (310.000 miles) so it might be a good solution.
Martin - what is the difference between this system and sleeve valves?
Martin_1962
« Reply #4 on: 15 June 2008, 19:23:48 »
Sleeve valves go up and down and are if you like liners
