Author Topic: rear window trouble  (Read 3099 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
rear window trouble
« on: 15 May 2014, 22:22:31 »
The nearside rear window has developed a problem of not re-closing after opening. It goes up then stops and goes down as if its hit an obstruction, has anyone else had this problem any help appreciated thanks :)
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Re: rear window trouble
« Reply #1 on: 15 May 2014, 22:23:28 »
First, easiest thing to do is to lub the channel it runs in .... and then go from there.  :y
Toledodude1973
  • IPSWICH U.K.
« Reply #2 on: 15 May 2014, 22:28:16 »
What would you use , ordinary grease or rubber silicone stuff?
« Reply #3 on: 15 May 2014, 22:48:34 »
« Reply #4 on: 15 May 2014, 22:53:07 »
Yep ...... what he said.  :y :y
Toledodude1973
  • IPSWICH U.K.
« Reply #5 on: 15 May 2014, 22:59:18 »
Thanks for help ;)
Toledodude1973
  • IPSWICH U.K.
« Reply #6 on: 16 May 2014, 19:27:40 »
Sprayed lots of silicone down the channels , after a few attempts the window eventually closed. It now works fine, so hopefully fixed, thankyou all :)
