Author Topic: Wheel spacer advice.  (Read 4286 times)
ted_one
Re: Wheel spacer advice.
« Reply #15 on: 17 May 2014, 17:54:10 »
Cheers Serek, 16 inch wheels.
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
« Reply #16 on: 17 May 2014, 19:33:02 »
I have 20mm hubcentric spacers on the rear of mine and have had no issues in the last 6 years. They make the tyres fill the arches much better.
I got mine from eBay.
Lee.
Elmstoneboy
  • Biddenden Kent UK
    • J reg 2.6 V6 Auto CDX
« Reply #17 on: 17 May 2014, 20:37:30 »
Nitro
Find a Waterjet cutting company near to you. They can cut what you like, just give all the dimensions and pitch circle
diameter of the holes. They will be able to cut any thickness you require within material stock sizes. T6 ali grade is 6082.
Waterjet is ok as it does not produce any heat or stress in the material.
If you happen to live in Kent near Staplehurst give us a call. Google Waterjet cutting Kent and look for the one in
Staplehurst with the funny name. We have done these before for other makes.  Our general tolerance is +/- 0.127mm  .005"
They will probably be a bit more expensive than stock items, as they are bespoke.
ted_one
« Reply #18 on: 17 May 2014, 20:42:27 »
Nice one Lee,
                     I did look at those and I think I might take a punt, because as you say they work for you,can't say fairer than that :y
ted_one
« Reply #19 on: 17 May 2014, 20:44:19 »
Many thanks Elmstoneboy,
                                        will take a look at the website as advised :y
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« Reply #20 on: 18 May 2014, 17:24:31 »
I run 20mm hubcentric spacers on the rear of mine, but then i also converted to studs instead of bolts too!  Well worth it Ken  :y
ted_one
« Reply #21 on: 18 May 2014, 17:26:00 »
Thanks for the info Paul :y
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
« Reply #22 on: 18 May 2014, 18:57:35 »
i have 5mm on the front and 20mm on the back looks and drives great :y :y :y
P6UL K
  • Dartford, Kent
« Reply #23 on: 18 May 2014, 19:42:56 »
Me too!  8)
ted_one
« Reply #24 on: 21 May 2014, 12:31:07 »
Hubcentrics ordered.....thanks to every one for the advice :y
