Author Topic: Engine fails to start omega 2,6v6  (Read 10269 times)
Re: Engine fails to start omega 2,6v6
« Reply #45 on: 30 May 2014, 18:24:12 »
Hopefully that will see it sorted :y
iirc, my cranksensor failed at around the same time as my fuel pump, so might be possible that when one starts to fail, it strains the other :-\ could just be coincidence though...
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #46 on: 09 June 2014, 20:26:57 »
Did you get it sorted Petter?
Petter
  • Horten, Norway
    • omega 2,6 v6 elegance
« Reply #47 on: 16 June 2014, 09:40:59 »
After almost a month I finaly got good news. After changing fuelpump the car started but run porly, and I got faultcode , P0305. So I changed the sparkplugs . Started the engine and problem solved  :y
Thank you all in here for your help in sorting this problem.
Petter .  ;D
Andy A
  • Bristol UK
« Reply #48 on: 16 June 2014, 11:07:08 »
Glade you got it sorted Petter. Well done.  :y
« Reply #49 on: 16 June 2014, 11:12:53 »
Indeed :y I bet that was starting to do your bonce in ::)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #50 on: 16 June 2014, 11:20:01 »
Yes, glad its sorted Peter.  :y
Until the next time then.  :)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #51 on: 17 June 2014, 08:46:40 »
Well done, Petter. Sorry it took so long.
As said in message 34, with a dead engine checking fuel supply and spark is always helpful. If both absent - quite likely on modern car - suspect the electronics. If no fuel supply, a long lead from battery terminal to pump will test pump.
Pages: 1 2 3 [4]  All   Go Up
