Author Topic: HBV Falied Again  (Read 1994 times)
The Omega Glory
  • Staffordshire
    • Elite Saloon
HBV Falied Again
« on: 17 May 2014, 23:01:03 »
Just replaced the Heater Bypass Valve on my 3.2 (a testing little job and cutting the hands to ribbons), the second in a couple of years. Took the top off the old one and there's a rubber seal inside. I presume this is the area that fails? Is there any alternative for the next time that might last a bit longer than the GM part or is this as good as we get? Any other possible reason for early failure? ???
Re: HBV Falied Again
« Reply #1 on: 18 May 2014, 09:09:59 »
It is essentially a service item :-\
Should add, they tend to fail in one of three or so places, the diaphragm being one of them... might have been a duff one, but mine is on its third since 2009 fwiw, all genuine too :y
« Last Edit: 18 May 2014, 09:13:57 by Taxi Al »
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #2 on: 18 May 2014, 09:47:02 »
I must say, why is it that when the car was new the parts would last 100K or 9-10 years and then parts fail. Ok that's a good life for the part, but then you buy new from dealer at extra cost and still the new parts fail in 1-2 years :-\ >:( why are they not the same as when the car was new and last another 9-10 years.
chrisgixer
« Reply #3 on: 18 May 2014, 10:02:34 »
They don't last 9-10 years ime. Non of my cars have been on the original hbv. And I've had three I considered my own cars as daily drivers, at various points, and a few others  sold on. All had been disturbed/busted off its bracket/cable tied to its post etc etc.
Any production line will have a few bad eggs. But two years is disappointing it has to be said. :(
There's no alternative though.
More modern cars don't have a valve at all.
« Reply #4 on: 19 May 2014, 18:05:07 »
IIRC, my bullet is still on its original. None of the other Omegas are, with the possible exception of Goldie, which didn't like me anyway.
I wonder if coolant servicing has an impact, as this is frequently neglected on "professionally" serviced vehicles.
chrisgixer
« Reply #5 on: 19 May 2014, 19:49:47 »
You are joking? After the state of your coolant at Wycombe? Lazy bloody admin! ;D
steve6367
« Reply #6 on: 21 May 2014, 10:58:41 »
Do you actually need it?
Does it only shut off the coolant to the matrix when you select 'LO' - which I don't think I've ever done....
Steve
« Reply #7 on: 21 May 2014, 11:28:41 »
It opens variably to allow more accurate control of the cabin temperature  :y
steve6367
« Reply #8 on: 21 May 2014, 14:12:45 »
Scrap that idea then  :y
« Reply #9 on: 21 May 2014, 14:27:39 »
That's not to say a servo controlled valve couldn't be fabricated to suit... Issues would be size/weight and converting the vacuum to a suitable electrical signal :-\
Page created in 0.029 seconds with 20 queries.
