Author Topic: Outside edge tyre wear  (Read 8923 times)
Re: Outside edge tyre wear
« Reply #30 on: 26 May 2014, 16:52:26 »
Post 23
http://www.omegaowners.com/forum/index.php?topic=122270.msg1556890#msg1556890
Hmmm, I can understand if there was no give at all. But there is (and must be) some.
That said, there would be less, thus less toe needed ?  :-\
« Reply #31 on: 26 May 2014, 18:24:22 »
Tunnie - you're plastic tyres don't count. They were so hard, even you could overdrive them, and that wear pattern looks like they have been overdriven. Or maybe your shagged suspension (at the time) hasn't helped ;D.  Was that wear on both fronts, or just one corner - I can't remember?
Both sides  :y
chrisgixer
« Reply #32 on: 26 May 2014, 18:33:15 »
Post 23
That's my thinking.
I think....  :-\ ;D
« Reply #33 on: 26 May 2014, 19:37:07 »
Post 23
That's my thinking.
I think....  :-\ ;D
But would zero toe be too little, given there is "some" give in the bushes? Plus you still have rubber in the verticals...
« Reply #34 on: 26 May 2014, 19:38:41 »
All this farting around with tyres to get best handling, wear rates ect, the amount you lot spend on tyres you might as well get a VXR8  ;D
In nearly 100k, I'm only on my 3rd set of tyres  ;D
« Reply #35 on: 26 May 2014, 19:44:04 »
Aye, but not even my nearly 80yr old mum (that'll piss her off, sorry mum!) drives as slow as you...
« Reply #36 on: 26 May 2014, 20:11:38 »
Unfair tag that, drive as normal folk do. 80mph cruise down motorways, about the same on country roads, I also have had 2 speeds tickets since I passed.
Some you just drive like nutters  ;D
chrisgixer
« Reply #37 on: 26 May 2014, 23:44:29 »
Post 23
That's my thinking.
I think....  :-\ ;D
Ah I see TB is struggling with this compromise thing, and that there are numerous fractions between 0.00 and 0.10 combined toe. ;D it's not like a throttle, on or off. There is an adjustment in between. ;) ;D
Maybe half the original toe setting...? See what Tony says perhaps? :) I can't see an issue provided it doesn't go into toe out. Maybe it already does on the brakes :-\ how to tell ? :-\
« Last Edit: 26 May 2014, 23:56:25 by chrisgixer »
chrisgixer
« Reply #38 on: 26 May 2014, 23:57:48 »
Vxr8 and monaro both need set, same as omega.
« Reply #39 on: 27 May 2014, 09:48:00 »
Directional instability under braking. :y
« Reply #40 on: 28 May 2014, 17:56:33 »
I've been having that until last night, in TBE. TBE has outside shoulder wear, more extreme than Mr Gixer's :(
« Reply #41 on: 28 May 2014, 17:57:35 »
so what has now changed ??  :)
chrisgixer
« Reply #42 on: 28 May 2014, 17:59:48 »
So what changed?
Too late
« Reply #43 on: 28 May 2014, 18:14:18 »
The car is much more stable under moderately hard braking (not tried a proper brake test yet).
« Reply #44 on: 28 May 2014, 18:17:15 »
New calipers perchance :-\
Pages: 1 2 [3] 4  All   Go Up
