Pages: 1 2 [3]  All   Go Down
Author Topic: "Nasty 4 pot diesel" problem (project car)  (Read 7771 times)
Re: "Nasty 4 pot diesel" problem (project car)
« Reply #30 on: 29 May 2014, 19:06:59 »
Apparently all the same, it's the same clutch used in the 2.6 / 3.2 and 3.0 and apparently 2.2 DTI.
My 3.2 estate had a gearbox from a DTI fitted, with the DTI clutch aswell. Seemingly it was exactly the same!
OK sorry chaps, I know it doesn't take much but I'm really confused
The consensus on here is that the 2.6/3.0 clutch kit is the same one that's fitted to the 2.2 DTi.
Yet - researching the parts on buypartsby website, only the 2.2 DTi one is the SAC (self adjusting clutch). The others just appear to be a normal clutch kit.
So - it can't possibly be the same clutch kit? As the 3.0 for example isn't self adjusting and doesn't need the tool? :)
Also - the buypartsby website specifically says that the 2.2DTi repset clutch kit they sell does NOT come with a release bearing! (unless you buy the "pro" one, which is over £100 more!!)
Yet - the 3.0 clutch kit listed does come with a bearing, and is just over £100.
I don't have a tool to evenly install the pressure plate on a self adjusting clutch.
Is there any good reason why I cannot or should not buy a clutch kit for a 3.0 litre model and just fit that? Would it cause any harm? The car will not be used for any towing at any point.
I'd really appreciate some opinions as I want to start the repairs ASAP :y
« Reply #31 on: 29 May 2014, 19:13:36 »
Wrong. Totally different part number on VX TC site
2.6/3.0 is 93185903
2.2DTI  is 93185906
No other Omega uses the 2.2DTI part number
« Reply #32 on: 29 May 2014, 19:15:07 »
2.6/3.0 is 93185903
2.2DTI  is 93185906
Cheers Rob. Can you check if the flywheel is the same part please? :y
« Reply #33 on: 29 May 2014, 19:15:48 »
And while your'e at it, please could you give me a part no for the release bearing on the 2.2 DTi, so I can see about getting one from VX if needsbe? :y
« Reply #34 on: 29 May 2014, 19:17:31 »
Only DMF listed is for the 2.2DTI #9201098
« Reply #35 on: 29 May 2014, 19:18:41 »
And is that different to the V6 ones? :)
« Reply #36 on: 29 May 2014, 19:22:59 »
Think it`s this one James 90465672
« Reply #37 on: 29 May 2014, 19:29:13 »
Unsure James. As said, TC site only lists the DMF for 2.2DTI :-\
    • 530D M Sport, 330i Coupe
« Reply #38 on: 29 May 2014, 19:41:59 »
I'm told the DMF is very robust in these.
« Reply #39 on: 29 May 2014, 20:07:15 »
My line of thought is that if it's the same DMF as v6, I could get away with a 3.0 clutch kit :y
serek
  • huntingdon
    • 3.2 mv6
« Reply #40 on: 29 May 2014, 20:07:42 »
V6 flywheel wont fit it to DTI !
you can try use clutch of V6 with dti flywheel
have both will check tomorrow in workshop if can be exhange
edit:
if you get stuck have tool here if you need to borrow :y
« Last Edit: 29 May 2014, 20:22:06 by serek »
« Reply #41 on: 29 May 2014, 20:29:55 »
The repset pro also includes a 'free' slave cylinder for the extra cash... About £90 separately :y
« Reply #42 on: 30 May 2014, 11:29:30 »
If you could please serek as I'm hoping to order the bits today :y
« Reply #43 on: 31 May 2014, 12:09:31 »
Just been looking up summat in the Vauxhall 2003 Omega sales brochure, and stumbled on this...
The petrol 2.2 (and presumably the 2.0) has a clutch diameter of 229mm.
The diesel 2.2 and the 2.6 (and presumably the 3.2) have a clutch diameter of 241mm. :y
The Dti and 2.2 have the same gearbox ratios. The 2.6 ratios are different.
All have different diff ratios too. :y
Pages: 1 2 [3]  All   Go Up
