Author Topic: Anyone for a nice DTi estate? Only needs a new high pressure pump..  (Read 12811 times)
joshwyatt
  • Oxford
Put a wanted add up here on oof for a pump  :y
If they were that easy to get hold of I'd have repaired my old DTi Elite.  :'(
Do the 2.2 pumps differ from one's fitted to the Astra G 2.0 DTI or Zafira?
    • 530D M Sport, 330i Coupe
The EDC's are coded to the application.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
tech 2/3 might be able to re code
Hoof'land storeman.
Nope
I am tempted to put in an offer, I must admit.. even if it only donated body panels to the 3.2! Though the mpg of a DTi does appeal..
One offer been put in , was it you aaron  ::)
Nope, wasn't me.. I've been busy today swearing (sometimes completely openly) at my so-called "colleagues" >:(
I'm still tempted, but suspect I'd fail-to-fix and then be sitting on a £4-500 paperweight (not forgetting a couple of hundred to get it collected) ;)
Buy it, send the fuel pump ecu off for repair and go from there... got to be cheaper than keeping that BMW working :-\
Buy it, send the fuel pump ecu off for repair and go from there... got to be cheaper than keepmaking that BMW working :-\
Fixed. :y
I'm guessing the driving experience might be a bit lacking in comparison, though... ::)
Just a little, Kev - though for a while there I was starting to find the M3 less than impressive dynamically; oddly enough a full bore emergency stop (to avoid "doing an Al" up the arris of a Ford Fiesta on the M40) seems to have improved it no end - it feels lighter, more pointy, chuckable. Odd. Anyway..
If I went to the oily side it'd be to replace the 3.2 - although maybe I should strip the 3.2 out, MV6 it and use that as a track toy. It'd be a giggle if nothing else ;D
If I went to the oily side it'd be to replace the 3.2 - although maybe I should strip the 3.2 out, and use that as a van.  ;D
Fixed :y
In answer to the former, all the loose bushes have probably been reset...
Incidentally, I might have found a solution to the 'victorian' gearchange, which doesn't involve fitting a slush box..but that's for another thread :y
I thought if you'd have fixed anything it would have been the "doing an Al" bit.. ;D
Interested in your thoughts on the signalbox gearchange, though  :y
If he does another "Al" with his new brakes, he really is past help. ;D
Ain't that the truth ;D
Well my £350 offer was rejected and countered with £500.. at that price I think it's too much given recover cost etc. Hmm.
Yep too much tell them to take it or leave it :y
Page created in 0.027 seconds with 16 queries.
