Author Topic: A/C HP Valve Part Number  (Read 3745 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« on: 30 May 2014, 18:32:25 »
Is this 13277003 the correct part number for the High Pressure valve for a 3.2 FL saloon ?
Was informed it's leaking from there. Typical it chooses  to piss it all out when it's hot  ::)
Thanks...
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: A/C HP Valve Part Number
« Reply #1 on: 30 May 2014, 19:18:21 »
If someone could confirm or provide me with the current part number tonight please, Ideally a part number that any VX dealer would recognise as I've given part numbers to them in the past which they know diddly squat about.. Failing that VX are of no use, Can they only be bought new from VX or is there another source..
As for changing the valve... 17mm and 15mm spanners required, Hold the base with the 17mm.. Something like this the procedure if I'm correct.
Also, Has anyone had the valve replaced at a VX dealer, Just curious as to how much they would charge or do they insist on changing the pipe as well ?
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #2 on: 30 May 2014, 19:44:10 »
Seems to be loads of different part numbers for this part  :-\
AndyB mentioned this part number on another thread.. 52458177
Jukeboxnut
  • West Sussex
    • 2004 2.2 auto CDX estate
« Reply #3 on: 30 May 2014, 19:46:20 »
13277003 is the correct part number which replaces the original part 52458177.  I bought one last week for my car but am still struggling to fit it at present as 15mm socket does not fit mine, good luck with yours.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #4 on: 30 May 2014, 19:47:19 »
Thanks mate, I can imagine it's going to be a bitch of a job.
« Reply #5 on: 31 May 2014, 08:40:13 »
Supply the part and ask whoever does the A/C regas to change it...   ...assuming they are not mongrels.
The A/C needs to be fully discharged first, and the do-gooders will complain about the trees and rising sea waters if you discharge it yourself into the atmosphere. If you do discharge it yourself, be aware that you risk extreme burns if you are not careful.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #6 on: 31 May 2014, 08:56:31 »
picture of said valve :y
[/img]
Hoof'land storeman.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #7 on: 31 May 2014, 09:03:08 »
Thanks got the info TB and Picture Griff  :y
Just a thought, Would one of those free A/C checks be a way to empty the system if they won't change the valve them selfs  :-\
(EDIT: there cant be much stuff left in the system if it's not cold/cool surely  :-\ .. I stuck a digital thermometer in the vent when it was around 20c outside and the A/C was blowing apparently 22c )
« Last Edit: 31 May 2014, 09:05:55 by Mr.OmegaMan »
biggriffin
« Reply #8 on: 31 May 2014, 09:19:48 »
if with the climate panel set to LO and engine running look at commpresor if its spinning it has gas, not spinning its empty.
 yes you could go to the free aircon check places you have nothing to lose its free.
 crap-fit offer the best deal not colder no charge, but they probablly try to sell you some tyres ;D
Hoof'land storeman.
biggriffin
« Reply #9 on: 31 May 2014, 09:24:29 »
Thanks...
the valve can be removed and cleaned with brake cleaner,they gum up with a/c dye and refrigerant. :y
also the lp valve's are prone to leaking, but these are a standard tyre core valve,which you replace using a tyre core tool, :y
Hoof'land storeman.
« Reply #10 on: 31 May 2014, 09:41:05 »
I had ShitFit regas one of mine about 4 times over a 3 month period. Then took it to someone who knew what they were doing, and it lasted ages (until the compressor disintegrated ;D)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #11 on: 31 May 2014, 19:36:32 »
Aye it is spinning..
Some progress today, Called VX and they where able to find the valve with the part number, Should get it on Wednesday and been in contact with ATS and they can change the valve and fill the A/C at the same time, Used them for years same lads worked there for years always helpful.
Hopefully that's that and the next update will be that it's working rather than something else wrong with the A/C .. Well here's hoping nothing else goes wrong, Then again we are taking about Omega's  ;D
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #12 on: 05 June 2014, 19:48:48 »
Finally changed the valve, The old one the green ring part of it was broken, That would explain the leak. Hopefully after a re-gas that's it....
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #13 on: 06 June 2014, 18:20:41 »
I had one of these and it fits the High Pressure valve like a glove.
19/32" 12 point AF Socket x 1/2" Drive
http://www.ebay.co.uk/itm/281069142356
Hope this helps others in the future  :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #14 on: 09 June 2014, 21:19:11 »
Had the A/C refilled at ATS for no extra charges, Said there wasn't any sign of any leaks, Hopefully it stays that way  :y
