Author Topic: what is this button?  (Read 9554 times)
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
Re: what is this button?
« Reply #45 on: 30 May 2014, 23:12:47 »
The last OOFer to press the button was Zirk and he ended up here.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #46 on: 31 May 2014, 08:06:03 »
Isn't that what happened to the last person that used non-VX cam cover gaskets? Unless it was me, I'm still here.
he was strung up using non GM crank sensor wire and covered in silicone sealent(booger it still smarts) ;D
Hoof'land storeman.
« Reply #47 on: 31 May 2014, 08:53:58 »
If its not saying anything when you press it, somebody has removed the box.
The system was shut down last year (or was it 2012), sadly. I found it a useful warning of upcoming traffic problems.
firemoth
  • Preston, Lancashire
    • Vauxhall omega 2.2dti est
« Reply #48 on: 31 May 2014, 09:42:08 »
It was pressed with ignition off if it makes any difference. It doesn't light up or anything either with ignition on
« Reply #49 on: 31 May 2014, 09:44:01 »
Ah, ign needs to be on.  But the network it needs to function has been shut down.
firemoth
« Reply #50 on: 31 May 2014, 09:52:12 »
So what happens if it's accidentally pressed? Wool it give a message for a bit then go away or will it just not shut up. Ie do I need to make sure it's all ripped out?
« Reply #51 on: 31 May 2014, 09:59:53 »
;D ;D
;D ;D
« Reply #52 on: 31 May 2014, 10:53:21 »
Only one way to find out :P
Just don't sit in the passenger seat, as the roof section removes and the ejector seat fires....
badmuver
« Reply #53 on: 31 May 2014, 14:43:48 »
Nooooo not that button, I have in mine I will be ripping it out soon  :D
Pages: 1 2 3 [4]  All   Go Up
