Author Topic: Coolant flush question  (Read 1655 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« on: 08 June 2014, 11:20:34 »
I understand about having the heater on full but why is it necessary to have the heater fan on full as well when bleeding the system?
I own a 2.2 petrol and the thermostat is easy to get too. I was also thinking about taking out the thermostat to flush the system quicker and save a lot of fuel not having to wait for the engine to come up to temp. Then put the thermostat back in for the last refill. Any reason why I shouldn't do it this way?
Thanks
Re: Coolant flush question
« Reply #1 on: 08 June 2014, 11:36:36 »
It's not necessary for the fan to be on full  ;)
Thanks
If the 'stat is easy to get to, then go for it ........... it's a plan!  :y :y
Andy A
  • Bristol UK
« Reply #2 on: 08 June 2014, 11:49:03 »
I'll give it ago. Should save a load of time.  :y
Andy A
  • Bristol UK
« Reply #3 on: 08 June 2014, 12:06:34 »
Do you know the tourqe setting for the two bolts?
« Reply #4 on: 08 June 2014, 14:29:23 »
If you have a Haynes manual, the torque will be broadly similar to the 2.0 16v ones :y
Andy A
  • Bristol UK
« Reply #5 on: 08 June 2014, 15:08:58 »
Just found one online.  ;)  :y
