Author Topic: Brake Servo 4 way non return valve  (Read 6203 times)
Re: Brake Servo 4 way non return valve
« Reply #15 on: 09 June 2014, 10:01:41 »
A better fix is to the drilling the valve where the snapped off spur is so that the broken off part can be inserted into it by 4-5mm.
Then insert and glue (ideal solvent weld) the broken part.
You loose a few mm of the length but thats not issue.  :y
LC0112G
« Reply #16 on: 09 June 2014, 15:24:56 »
New valve is £14.80 + VAT list from Vauxhall.
Scrappy pipe was the superior 4 way valve type, in decent nick, and £5 for cash.
Guess which one won? ;D
chrisgixer
« Reply #17 on: 09 June 2014, 18:49:32 »
I wonder ;D
