Author Topic: Dash Cam Power Sorce  (Read 16407 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« on: 11 June 2014, 14:31:28 »
I'm planning on wiring a power feed from the reading light area (for a dash cam) This dash cam if it helps... http://www.amazon.co.uk/dp/B00FKTQ3NE/ref=cm_sw_r_udp_awd_1LfMtb1SA5XJY
I want to use the same power source as the line that the camera starts recording as soon as I unlock my doors. (and stays on 5 minutes after the car is shut off or however long the timer is set at)... Could someone point me in the right direction ideally with a picture :)
Has anyone done this before ?.. I don't fancy using the cigarette lighter to power the bloody thing wires dangling all over the place.
Also would this be possible to do with a rear dash cam also with one of the rear side reading lights ?
Thanks in advance  :y
Re: Dash Cam Power Sorce
« Reply #1 on: 11 June 2014, 14:34:16 »
Can't help with power, some here know my wiring skills  ::)
Looks compact though, good to see how you get on  :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #2 on: 11 June 2014, 14:40:30 »
Exactly my thoughts, Decent reviews, Should just fit behind the mirror hopefully...
Not sure what the difference between the one above and this one LINK apart from the price and sticky 3M to hold it... Going by the 5th picture it's a pretty good fit behind that mirror.
« Last Edit: 11 June 2014, 14:42:05 by Mr.OmegaMan »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 11 June 2014, 15:51:38 »
Theres 12v behind the Courtesy Light, just make sure the Camera lead is fused  ;)
« Reply #4 on: 11 June 2014, 15:54:14 »
Tap into the sunroof feed :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #5 on: 11 June 2014, 16:17:37 »
Which wires are they not been up there under the skin before.
Where's RobG with his pictures  :P ;D :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #6 on: 11 June 2014, 16:37:35 »
That's basically the same unit I have. It fits behind the mirror under the shading on the screen and is barely visible from inside or outside the car.
Mine is wired to the ignition switched side of the sunroof, so it switches on and off automatically. I used a 12volt to USB converter(about £4 from EBay) tucked in the roof space. That leaves about 3cm of wire visible where it emerges from the edge of the roof lining.
I was surprised how good the picture is, and how easily the software syncs it with the GPS.
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #7 on: 11 June 2014, 16:51:13 »
Poundland sell those 12V to USB adaptors, obviously for £1, and also, but not for your application, a cigar lighter plug to one USB plus two cigar lighter sockets - same price!
Ron.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #8 on: 11 June 2014, 17:07:58 »
How could I add a fuse to it  :-\, Wouldn't want that little camera setting fire to the car  :o
Ron.
Forgive me for being stupid I'm not much of a electrician, What would I need one of those 12v to USB for and is it one of these you mean ? http://www.ebay.co.uk/itm/291100650160 / http://www.ebay.co.uk/itm/190733956225
  • Chatham, Kent
« Reply #9 on: 11 June 2014, 17:09:52 »
What I used is a little box about the size of a disposable lighter, wired to the car on one side, and an integral micro-USB lead on the other. I'll dig out a link when I get home.
  • Chatham, Kent
« Reply #10 on: 11 June 2014, 17:13:26 »
The camera should come with an adapter like those EBay links, but they're big, ugly, take up the cigarette lighter and trail wires everywhere. You wanted a more discreet solution, which hardwiring it gives you.
Bigron
  • Witham, Essex
« Reply #11 on: 11 June 2014, 17:27:48 »
I checked that link again and you don't need a USB adaptor - the voltage range is 12 - 24 volts!
Nick must be using a different model that requires 5 Volts, hence the need for the USB adaptor.
However, a fuse is essential, so look at Maplins site for a small, in-line fuseholder.
Ron.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #12 on: 11 June 2014, 17:34:32 »
Ron.
Thanks for the clarification Ron  :y
Regarding the inline fuseholder something like this (LINK)is required with a 12V fuse.
  • Chatham, Kent
« Reply #13 on: 11 June 2014, 17:34:45 »
That's exactly how mine was sold. But it's a USB device, which are 5volt. The car charger it comes with is 12 or 24volt, with a USB output. Some sort of adapter will be necessary, as the device's internal battery is only good for about 10minutes.
Bigron
  • Witham, Essex
« Reply #14 on: 11 June 2014, 17:44:25 »
I stand corrected! Ok, back to square one - you DO need an adaptor, and it my be that the Poundland one has a fuse, too, otherwise the one you linked to is fine.
Ron.
Pages: [1] 2 3 4  All   Go Up
