Author Topic: Front Subframes  (Read 3242 times)
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
Front Subframes
« on: 12 June 2014, 17:05:06 »
Are the front subframes found on the Omega different between cars with different engines (four-pot / six-pot) or is it just the mounts that are different? Thanks.
PM with your requests.
davieboy0312
  • wishaw
    • 3l V6 saloon
Re: Front Subframes
« Reply #1 on: 12 June 2014, 19:52:09 »
think there the same subframes mate
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Front Subframes
« Reply #2 on: 12 June 2014, 21:35:26 »
think mounts are different. why do you need one ::) ::) might have one
Hoof'land storeman.
humbucker
  • Cambridgeshire
Re: Front Subframes
« Reply #3 on: 13 June 2014, 09:09:54 »
Thanks guys. Are the 2.0 / 2.2 mounts the same?
Re: Front Subframes
« Reply #4 on: 13 June 2014, 10:31:52 »
2.0 and 2.2 same as engine is almost identical :y
humbucker
  • Cambridgeshire
Re: Front Subframes
« Reply #5 on: 13 June 2014, 10:37:15 »
Perfect. So, common subframes between V6 and four-pots, and mounts the same on 2.0 / 2.2. Nice one.
Re: Front Subframes
« Reply #6 on: 13 June 2014, 10:56:37 »
I dont recall the V6 and 4 pot subframes being exactly the same, the straight six diesel is also certainly different from memory
humbucker
  • Cambridgeshire
Re: Front Subframes
« Reply #7 on: 13 June 2014, 11:02:34 »
Aha! The plot thickens...
Re: Front Subframes
« Reply #8 on: 13 June 2014, 11:07:18 »
If someone has the pic from EPC it becomes quite obvious from memory (but its been a few years)
Re: Front Subframes
« Reply #9 on: 13 June 2014, 11:09:13 »
I'm not very good with the EPC .. but that doesn't list a "subframe" but does list a "front axle crossmember asssembly //which looks suspiciously like what I think is the subframe ....
It lists a LOT of different versions !!
17 CROSSMEMBER, ASSY., FRONT AXLE (NLS.- USE 9156600 3 02 028 ) 20SE, X20SE, X20XEV  -X1999999 (90445704)
  17  CROSSMEMBER, ASSY., FRONT AXLE 20SE, X20SE, X20XEV, Y22XE, Z22XE Y1000001-  9156600
  17  CROSSMEMBER, ASSY., FRONT AXLE X25XE, X30XE R1000001- R1127218 904457056
  17  CROSSMEMBER, ASSY., FRONT AXLE (NLS.- USE 9127270 3 02 023 ) X25XE, X30XE R1127219- S1097179 (90496649)
  17  CROSSMEMBER, ASSY., FRONT AXLE (NLS.- USE 9127270 3 02 023 ) X25XE, X30XE S1097180- X1999999 (90497931)
  17  CROSSMEMBER, ASSY., FRONT AXLE X25XE, Y26SE, X30XE, Y32SE Y1000001-  9127270
  17  CROSSMEMBER, ASSY., FRONT AXLE (NLS.- USE 9156602 3 02 030 ) X20DTH  -X1999999 (90539420)
  17  CROSSMEMBER, ASSY., FRONT AXLE X20DTH, Y22DTH Y1000001-  9156602
  17  CROSSMEMBER, ASSY., FRONT AXLE (NLS.- USE 9156601 3 02 029 ) U25TD, X25TD  -X1999999 (90445706)
  17  CROSSMEMBER, ASSY., FRONT AXLE X25TD Y1000001-  9156601
  17  CROSSMEMBER, ASSY., FRONT AXLE Y25TD   9266156
« Last Edit: 13 June 2014, 11:13:20 by Entwood »
Re: Front Subframes
« Reply #10 on: 13 June 2014, 11:15:48 »
Thanks Entwood, thats the part  :y
As I thought, removing the supersessions (as they are plug n play) gets:
So a single one for all 4 pot petrols (no surprise as they all use the same block pattern), a single one for all 4 pot diesels (again no surprise as they are a common block pattern), an early and late V6 one (2 in total, intereting as they must have made a change for some reason), a single straight six diesel with dis pump and a single straight six common rail diesel (not available in the Uk)
« Last Edit: 13 June 2014, 11:19:08 by Marks DTM Calib »
humbucker
  • Cambridgeshire
Re: Front Subframes
« Reply #11 on: 13 June 2014, 11:29:33 »
Thanks guys.
