Author Topic: central locking.  (Read 2307 times)
mickyboy123
  • brighton
  • hi
    • 2.2 cd omega.petrol auto
central locking.
« on: 14 June 2014, 12:32:06 »
hi chaps, have a little problem with passenger front door it wont lock or unlock with central locking, unlocks fine by hand tho. any sugestions plz. ::)
Re: central locking.
« Reply #1 on: 14 June 2014, 12:36:28 »
Most likely the door locking motor. There are some guides for removal/replacement, and a guide for replacing its internal switch (which is the most common reason for failure)
flyer 0712
« Reply #2 on: 14 June 2014, 14:46:57 »
Yep mine was the drivers door.....took the advice from here and bought one off here....£17.....fitted and now purfect :y
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« Reply #3 on: 14 June 2014, 20:09:36 »
I have the drivers door motor to do on mine, the guide is good ,have you any further tips as you've just done one? thanks
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Magwheels
    • 2.2 dti Elite saloon
« Reply #4 on: 14 June 2014, 20:17:41 »
I did both my front ones, changed the micro switch, RS Components still do the correct switches. Not hard to do but a bit fiddly getting the door lock solenoid's apart as you need to unclip the cover from the body which needs three hands! In the  end I levered the case up and slid some old feeler gauges in the gap to stop it snapping back together. They now work fine and total cost nowt as my mate got the switches through work. The only trouble is that the postage works out more than the cost of the switches. Read the info placed in the forum and it shows all you need to know.
Toledodude1973
  • IPSWICH U.K.
« Reply #5 on: 14 June 2014, 20:19:00 »
thanks for help
flyer 0712
« Reply #6 on: 14 June 2014, 20:40:32 »
The worst bit i found was the devil of a cover that covers the top of the solenoid inside the door,,apart from that a good job to do and well worth it. :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 15 June 2014, 13:13:53 »
What is the part no of the microswitch. Is there only one or two switches to replace.
Magwheels
« Reply #8 on: 15 June 2014, 14:48:51 »
http://oldsite.omegaowners.com//forum/YaBB.pl?num=1275155915
Its all there, very well written with good images, the part number is also listed there. You only need one switch per door locking motor and that is all I changed. I tested mine and found that whilst it worked one way I did not switch the other. One of the switches on the unit does not have an effect when using the fob. The drivers and passenger side are the same unit and the second switch on the drivers side switches the locking from the key. Apart from getting the door lock motor apart due to the clips the only part I found frustrating was getting the wiring undone from the motor as there is not a lot of room to get your hands inside the door and they were very tight with short wiring. Can be done though!!
« Last Edit: 15 June 2014, 14:52:13 by Magwheels »
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #9 on: 16 June 2014, 15:19:21 »
Did you unclip the wiring from the bottom of the door this makes things a lot easier
