Author Topic: rounded torx bolt  (Read 5218 times)
mcd840
  • Alloa
    • vectra cdx
rounded torx bolt
« on: 14 June 2014, 19:23:36 »
hi, in my attempt to fix the common"clunk" through the steering on my vec b due to the torx bolts needing replaced and re-torqued perfectly i have taken the head right of the bottom bolt whiltst trying to get it out, totally rounded it. i have managed to get a hack saw and cut a deep groove in it for a screw driver but its still very tight and dont want to bugger the bolt any more than i allready have, would applying abit of heat to it help as there will be lock tite on there aswell ?
thanks
b4ndit
Re: rounded torx bolt
« Reply #1 on: 14 June 2014, 19:46:43 »
weld a nut on it and the use a socket to undo it :y
mcd840
  • Alloa
    • vectra cdx
« Reply #2 on: 14 June 2014, 19:50:42 »
good idea, just like a spot weld ??
b4ndit
« Reply #3 on: 14 June 2014, 22:03:29 »
Yes but make sure you put enough weld on to hold the nut as the bolt will be tight, if not enough weld it will come off :y
mcd840
  • Alloa
    • vectra cdx
« Reply #4 on: 14 June 2014, 23:37:32 »
Ok, is it worth trying my original idea first with heating the bolt to melt the loctite then trying the screwdriver in the groove i made ?
b4ndit
« Reply #5 on: 15 June 2014, 10:02:56 »
worth a try :y
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #6 on: 15 June 2014, 11:16:41 »
If you've already cut a groove in it for your screwdriver then I would apply some heat to it before mucking about with weld. Also, use a screwdriver bit on a torque wrench or breaker bar, will be easier to shift after heat. I had the exact same problem when removing the seats from my MV6. Heat worked a treat. Neat.
PM with your requests.
chrisgixer
« Reply #7 on: 15 June 2014, 11:22:46 »
Failing that. Drill the head off and replace the bolt, if all else fails.
mcd840
  • Alloa
    • vectra cdx
« Reply #8 on: 15 June 2014, 18:19:54 »
Tried heating and using the screw driver bit on wrench with no joy. Also tried screwdriver. Keeps coming away from the bolt . Its very tight. Next thing will be seing who can weld. Would garages feel confident in welding a bolt down in the footwell ?
« Reply #9 on: 16 June 2014, 00:04:25 »
Why not ask one ::)
mcd840
  • Alloa
    • vectra cdx
« Reply #10 on: 16 June 2014, 18:31:25 »
spoke to a guy the day, he can do it but its one of them "time consuming" tasks -  drivers seat out, carpet pulled back, trims of etc
flyer 0712
« Reply #11 on: 16 June 2014, 20:58:28 »
Have you tried an impact screw driver and they when whacked with big hammer produce plenty of force to shock them into undoing. :y
mcd840
  • Alloa
    • vectra cdx
« Reply #12 on: 16 June 2014, 21:39:18 »
no i havent, i will look into that
cheers
« Reply #13 on: 16 June 2014, 21:45:23 »
cheers
you might be able to hammer on a slightly smaller ordinary socket on the Torx head & use the impact driver  :-\
mcd840
  • Alloa
    • vectra cdx
« Reply #14 on: 16 June 2014, 21:57:27 »
tried that mate but theres bugger all left on the head to get a grip off, its all rounded away. the car had a new steering rack fitting around 3 years ago and when they tightened the bolt they seem to have made an arse off it ! ive only noticed after the "clunk" starting to re-appear. looking at easy out kits on ebay just now but doubt they will be much use
