Pages: 1 [2] 3  All   Go Down
Author Topic: Audi A3 TDi issue  (Read 7516 times)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Audi A3 TDi issue
« Reply #15 on: 03 July 2014, 15:01:32 »
As per above post...
Flywheel fell to bits and jammed into bell housing.
Engine now turns freely :y
Christ :o,thats not good is it ???
other rides
« Reply #16 on: 03 July 2014, 15:24:16 »
That must have been banging and knocking for ages with the usual multi clonk on start-up and rattle with clutch pressed that you get on a very bad DMF failure
« Reply #17 on: 03 July 2014, 15:25:36 »
Only 70k too  :o
« Reply #18 on: 03 July 2014, 15:33:22 »
Now you have me wondering if that's the noise the M3 is making... would that rattle sound at all like a tiny jackhammer somewhere under the car? Goes away as soon as the pressure plate starts making contact with the flywheel?
« Reply #19 on: 03 July 2014, 15:44:12 »
Yes, other classic sign is start it up with the clutch pressed, do you get a short rattle then?
« Reply #20 on: 03 July 2014, 15:48:25 »
I'm a BMW driver so I'm naturally lazy - the computer takes care of that third pedal business.. ;)
It's an SMG-II so I can make it dis/engage the clutch when started, but I don't know if it starts with the clutch depressed or not.. actually thinking about it the diagnostics tells me the position of the actuator so I can probably check that (and actuate it if it's not already) when starting :y  I'll give that a try at the weekend
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #21 on: 03 July 2014, 19:52:11 »
Mate at work has one of these. 54 plate Tdi.
He has had it recovered to me after a breakdown
Symptoms, he described a noise like a hamster in a ball. He said it got worse and he turned off the engine.
I've had a very brief look and have determines -
Cam-belt intact and in good shape
No holes in block
Oil level full
No warning lights came on inc no oil pressure lights
Any thoughts? I'm wondering if the dual mass flywheel has failed and somehow is jamming the crank?
Good call James. :y :y :y
« Reply #22 on: 09 July 2014, 22:46:48 »
New flywheel and clutch kit fitted. Getting the box on single handedly was a struggle I'm shattered. A few bits to do before she can be driven, but she starts and idles lovely :y just thrilled it's not seized :y
henryd
  • west cornwall
« Reply #23 on: 10 July 2014, 09:32:37 »
Is it a six speeder ?,if so they are bloody heavy,gears must be made of lead :-\
other rides
« Reply #24 on: 10 July 2014, 09:36:43 »
I recon the FWD VW diesel is the worst car out there for changing the clutch on, even worse with a DSG
« Reply #25 on: 10 July 2014, 09:37:03 »
I don't actually know, I've just been putting it back together like a big Lego set ;D
« Reply #26 on: 10 July 2014, 09:38:21 »
Makes me feel better for doing it :D what would you say is bad about it?
Can't be any worse than likes of Mondeo where the subframe is in the way?
« Reply #27 on: 10 July 2014, 11:28:43 »
Its heavy and a shitter to align.
« Reply #28 on: 10 July 2014, 20:23:30 »
Fully agree!!!!!!! :y
tidla
  • solihull
« Reply #29 on: 10 July 2014, 22:15:12 »
At least you didnt have to cut the centre out to get at the flywheel bolts! stupid things.
Pages: 1 [2] 3  All   Go Up
