Pages: 1 [2] 3  All   Go Down
Author Topic: Any MS Excel experts in here?  (Read 5457 times)
  • Auckland
    • Mazda MPV
Re: Any MS Excel experts in here?
« Reply #15 on: 25 June 2014, 19:36:30 »
Use Frequency?  Done similar, recall basic freq wizard did the job :-\
There was some issue around doing the dates when I played earlier today, then I got sidetracked onto Pivot Tables, and lost 3 hours of my life without achieving anything useful.
Been there. :( 2 years of hourly readings from the heat meters in a block of 90 flats.
I did manage to get some answers but it wasn't pretty.
I considered saving all the data in a csv file and writing something to suck it all into a mysql or sqlite database but never got around to it.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #16 on: 25 June 2014, 19:37:43 »
You need to use the COUNTIF function :y
http://office.microsoft.com/en-001/excel-help/count-how-often-a-value-occurs-HP001127779.aspx
Edit:  you can nest the COUNTIFs with IF statements as required
I Must type faster!
 ;D
I may or may not have spent a whole year in my yoof doing nothing but excel and VBA  ::)  (which is the most convoluted way to go about this problem)
« Reply #17 on: 25 June 2014, 19:39:16 »
on complex scenarios using excel built in functions will get more complicated :-\
Gaffers
« Reply #18 on: 25 June 2014, 20:06:59 »
True, but this is not complicated for Excel.  In fact it is exactly what is was designed for?
jimbobmccoy
  • outer london
« Reply #19 on: 25 June 2014, 20:18:30 »
I Must type faster!
 ;D
I'm currently being tormented by reports for work that are a combo of excel, VBA and tying it together with macro scheduler to achieve some level of automation. Convoluted isn't the half of it!
I try to convince myself it's all good for my 'personal development' but when 64bit excel just decides to stop liking existing VB, it's testing. (Apparently a known issue and why Microsoft recommend using the 32 bit version unless absolutely necessary ???)
Gaffers
« Reply #20 on: 25 June 2014, 20:33:20 »
Ok, because I am a nice chap, here we go :y
Number of times name appears - =COUNTIF(C2:C16, "matt")  where C2:C16 is the range of cells and "matt" is the name
Number of times name appears with Action=Yes - =SUMPRODUCT(--(C2:C16="matt"),--(D2:D16="yes"))
Number of time name appears in last 30 days - =SUMPRODUCT(--(C2:C16="matt"),--(E2:E16<(TODAY()-30)))
Number of time name appears in last 30 days with Action=Yes =SUMPRODUCT(--(C2:C16="matt"),--(D2:D16="yes"),--(E2:E16<(TODAY()-30)))
Gaffers
« Reply #21 on: 25 June 2014, 20:33:48 »
Now give me a real challenge ::)
« Reply #22 on: 25 June 2014, 21:09:47 »
as the murphy rules says it will always get complicated as time goes by ;D
« Reply #23 on: 25 June 2014, 21:10:39 »
believe me I can :) :y
« Reply #24 on: 26 June 2014, 17:24:55 »
Importing into a DB is a no-go I'm afraid. That was the way I wanted to go.
Can you not stick sqlexpress on your own machine, create a one table DB and do it locally on that?
Will anyone mind as long as the output is right?
Also, from experience, management tend to want this type of report to grow-get more complex, analyse the same thing more times, and still not get what it's telling them. As this happens having the info in a proper DB would be a huge help
It has to be self contained and independent of anything else. You're preaching to the converted about databases, but that's not an option.
To really add insult, the data has to be updatable via Excel Webapp, as found on whatever Skydrive is called this week, and ShitPoint.
Grrrr
« Reply #25 on: 26 June 2014, 17:27:56 »
I'm failing at a hurdle before - I have a list of names, but this list will change over time, as will the number of names in the list.
« Reply #26 on: 26 June 2014, 17:30:33 »
Instead of ="matt", can I have =NameList!A2 instead, would that resolve it? (assume name was stored in NameList!A2) ?
Then with an IF to ensure that NameList!A2 is valid
Gaffers
« Reply #27 on: 26 June 2014, 18:00:40 »
You can reference a single cell easily, but if you wanted to do a number of names in to one result you would need to add OR statements before the first comma by "matt".  Something like:
=SUMPRODUCT(OR(--(C2:C16="matt"), --(C2:C16="Jimbob")),--(D2:D16="yes"))
For a list of results for different names you would need to do a separate formula for each name you waned to count.  SOmething like this:
=SUMPRODUCT(--(C2:C16="Jimbob"),--(D2:D16="yes"))
« Reply #28 on: 26 June 2014, 18:23:41 »
I think that gives me a starter to work from :y
Gaffers
« Reply #29 on: 26 June 2014, 18:44:00 »
No probs, the hard part is getting the commas and brackets lined up properly ::)
One tip is to fabric some test data to which you already know the outcome and test your formulas on that :y
Pages: 1 [2] 3  All   Go Up
